V70 XC 2001 throttle hesitation
Japedo
Post by Japedo »
My wifes XC has 155miles on it now, recently there is a hesitation of between 1 and 3 seconds when you press the accelerator.
Is a real pain while driving in town and trying to pull out into traffic, as you could imagine.
I don't have any ETM codes, but the digital message screen is reading "engine system service required" and "engine system service urgent".
Anyone have any ideas, I think it is trying to tell me something. :?
Curtis
2003 v70 2.5tawd black/black 120miles
2007 nissan altima 2.5 cvt 107miles
2001 xc70 211 miles " collision"/ parts car
1994 850 turbo 315miles 5 speed "stoped fixing it"
Steely
Post by Steely »
Possible MAF problems. Have you read this?
https://www.matthewsvolvosite.com/forums ... =9&t=26833
Nice writeup by E170_Driver.
8)
'01 V70 T5
Japedo
Post by Japedo »
steeley- Thanks for the link on the maf info, however I don't think that is my problem. I haven't had any idiling issues whatsoever car starts great and runs smoothly.
I just have the hesitation with the gas pedal, like it takes a few seconds to comunicate with the car when I press the pedal.
This delay that I am talking about happens regardless of speed. It is quite a small delay while accelerating from a stop, and the longest delay I notice is while cruising at 50mph "2100 rpm" . When I pucsh the pedal from 1/4 throttle to 3/4 throttle at this speed the delay is atleast 3 seconds.
No transmission codes and the shifting is very smooth.
Anybody have something like this happen to them? Logically it seems like the ETM to me but there are no codes/ messages to support it yet.
Thanks
Japedo
Post by Japedo »
Anybody have any ideas here? I really don't want to bring this thing to the dealership.
I'm going to spray some electrical cleaner on the maff and see if that changes anything but it is working great other then that hesitation, as well as averaging 24.5mpg.
Thanks floks
Joe Hurless
Year and Model: e36 328is
Post by Joe Hurless »
Japedo wrote: I don't have any ETM codes, but the digital message screen is reading "engine system service required" and "engine system service urgent".
This would be easy do diagnose if you could pull the code that the check engine light is throwing (service engine soon=check engine). However, your problem sounds like and air flow issue or, very likely with your mileage, a bad coil causing a misfire.
If you can get that code, we can pinpoint it.
E170_Driver
Year and Model: bye V70 2.4T, 2001
Post by E170_Driver »
Japedo wrote:Anybody have any ideas here? I really don't want to bring this thing to the dealership.
Thanks floks
It could also be a vacuum leak with one of the hoses at the throttle body or leaking intake manifold (tough ones to diagnose)...
Jan
Former 2001 V70 2.4T owner
Japedo
Post by Japedo »
I don't believe it is a bad coil, ive had to replace a couple of them in the past few years on this car. But when they were bad it didn't cuuse a hesitation in the throttle, just ran really rough.
Maybe it is a vacume leak of some sort, cleaning the maff sensor didn't help at all. Does anyone know where I could locate a vacume hose diagram for a 2001 XC? I'll borrow my frinds obd2 reader and see waht the codes are. I know there hasa lways been a P0422 code and mybe the cat has gotten worse..
Thanks
Joe Hurless
Ok, it sounds like a large airflow leak. Either that or a bad air mass meter. I always check the connections of all the airflow and turbo hoses on the car before replacing the air mass. Sometime there will be a massive rip in a turbo hose that you can only see with a mirror. If all the hoses and connections look good, try swapping the air mass meter. Some shops, like ours, will install the part for you to see if it fixes it and trade you back if it does not.
Japedo
Post by Japedo »
My wife stopped at the dealer today and got them to read the codes, print a bunch of stuff out and maybe tell us what the problem is.
The surprising thing is that they did it for free! I was expecting atleast 80$ so im pleased.
This is what they found and it seems to explain my throttle hesitation.
ECM-9180 Accelerator pedal (ap) position sensor - faulty
ECM- 9530 Accelerator pedal (ap) position sensor - faulty signal
ECM- 958F Accelerator pedal (ap) position sensor - faulty signal
ECM - 959F Accelerator pedal (ap) position sensor - faulty signal
THey checked my ETM out and said that thier are no faults found for this system, I also got them to print out the service records and according to that the ETM was done at 78miles and I got the car at 88miles.
Hopefully my issues are directly related to the "accelerator pedal position sensor"
Anyone know an aftermarket sensor/pedal assembly for these cars? is it plug and play or do I need software to make it work. Thanks folks
Dealer quoted 192 $ for the pedal assembly with sensor.
Esnoyer
Year and Model: V70 03
Post by Esnoyer »
You must have a great Dealer ,mine charged $118.00plus tax to read my codes, my ckeck engine light came on.. It was a vacume leak the gas cap was the problem It was replaced with a VOLVO CAP for about $35.00 !!!!!!
