FCP Video Walkthru: S60 Timing Belt Replacement
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
This topic is in the MVS Volvo Repair Database » S60 Timing Belt Marks
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2650 times
Been thanked: 1240 times
Volvo Repair Database FCP Video Walkthru: S60 Timing Belt Replacement
Post by matthew1 »
"Jay Van Gorden, Volvo Master tech is back again to walk you through a full timing belt, serpentine belt, roller and tensioner replacement on a 2003 Volvo S60 using an OEM timing belt kit from CRP Industries."
Also -> Amazon link
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Great video.
I have some suggestions to do in addition to what in on video.
Make a serpentine belt routing diagram. Volvo does not put a label anywhere and cleaning up and doing google and other searches for the info tends to make you angry.
ALWAYS paint or crayon mark your marks on the cams. They will often not be perfectly aligned and if they move you will wonder if it was off to the left or to the right when it doesn't align perfectly. Marking saves that angst.
I recommend removing the computer box lid and body. These come off without removing the modules inside and make access mush easier.
4 and 5 cylinder have tensioner moved to the left to increase tension. 6 cylinder engines have tensioner moved right to increase tension.
537playing
Year and Model: 2005 S60
Has thanked: 1 time
Been thanked: 5 times
Post by 537playing »
Excellent video
igel513
Year and Model: 2003 S60 T5
Has thanked: 1 time
Post by igel513 »
That was a great video. He made it look so easy.
537playing
Has thanked: 1 time
What is that extention handle that he used in combination with thevwrench to remove/install the serp belt?
ONV70XC
Year and Model: 1999 V70 XC
Post by ONV70XC »
The video is great, but I will suggest to add jimmy57 additional comments.
fazool
Year and Model: S60, 2007
Been thanked: 7 times
Post by fazool »
537playing wrote:What is that extention handle that he used in combination with thevwrench to remove/install the serp belt?
I think he called it a "serpentine belt tool" it looked like a flat bar with a 14mm nut welded on the end. The box end of a 14mm wrench goes in there and then the open end of the 14mm wrench goes on the pulley bolt. Thats what it looked like.
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
ONV70XC
Post by ONV70XC »
I use wrench with pipe instead. The belt tool is near $40 at Autozone to purchase or to loan with full refund.
70one
Year and Model: S60 T5, 2002
Post by 70one »
Great video, but can someone post torque specs? I don't feel comfortable with just letting the air gun set torques. Also, if hand torquing the crank pulley, how do you keep the crank from rotating? Thanks.
Torque for:
idler bolts
tensioner bolt
crank bolts
crank nut
shock tower brace bolts
pkc303
Year and Model: 1995 T-5R Yellow
Has thanked: 1 time
Been thanked: 3 times
Post by pkc303 »
Good video, but if you don't have the air tools, it is easier to leave the crank pulley on, and removed the two bolts on the plastic guard toward the front of the pulley. Then the flossing of the belt off and on around the crank pulley.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
