09 S60 tail light bulbs
one left tail light bulb on my wifes s60 went out, wiggled the bulb, it worked for a short while. went out again, replaced the bulb, no go. now neither tail light bulb on the left work. checked the fuses in the trunk panel, visually good and test good with a meter. is there a known issue with the bulb holder or does anyone have any other troubleshooting ideas? I may try to swap with the right bulb holder.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Disconnect battery, touch the removed ground cable to the pos cable for 3 or more seconds and then put the ground cable back on.
OR clear the codes with a COMPLETE car code reader, OBD-II gizmos will not do the codes other than ECm and TCM.
- 825 Views
Last post by jonesg
- 1322 Views
Last post by Turbo_Boss
- 1049 Views
Last post by Brucebo
- 5241 Views
Last post by AVOIT17
- 723 Views
Last post by Vovo_merz
