Used radio code- V70- 2002
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 151 times
Been thanked: 4 times
Post by Mr. Detail »
My radio went on the fritz after 223k miles and I found a used one (HU-613) on eBay but the speak of needing a code to make it work. Do I need to go to a Volvo dealer to get this code? Obviously the seller pulled this from a bunker and doesn't have the VIN.
br0dy519
Year and Model: 2004 XC70
Has thanked: 126 times
Been thanked: 116 times
Post by br0dy519 »
Radio code is a Volvo 850 issue. Not an issue with the P2's.
04s60 2.4
04xc70 2.5t
Mr. Detail
So br0dy519, you are saying that if I purchase a used radio to match my present old one (HU-613) I won't have to worry about it turning on when I plug it in?
Has thanked: 1851 times
Been thanked: 1712 times
Correct. It was a - 2000 MY issue. P2 it is not an issue. As they made the radio a unique shape for Volvo's I have never heard of one being stolen. Because they did that I assume Volvo did not see it necessary to use a code for it.
Good luck with the swap.
Mr. Detail
Thx much Neil.
Now I just need to make sure the seller has tested the used one for working order.
Mr. Detail
Heh guys. One last look at this. Can you take a quick look at this used radio I was thinking about buying on eBay?
https://www.ebay.com/itm/406533527968?m ... name=11051
The seller is saying that my VIN (YV1SW61R221256378) shows a Model "HU-413" radio when the actual radio in my base v70 shows a HU-613. Kind of confusing as the listing is for a HU-613.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
I would get a large LCD touchscreen screen , double din with rear camera , smart phone integration, GPS , etc, $150 maybe. Amazon
along with adapter front plate and plug kit to match what you have, look at the back of your radio before ordering.
Mr. Detail
Wow, jonesg, I didn't think I could get something that modern for around $150. I will check it out. Thanks!
Good luck finding something at that price these days. I wish you luck.
The question you ask is if the unit is an HU-613. The part number on the top 8651153 relates to a HU-613, as does the large 613 on the label.
I think it may have had an aftermarket 'wood' front glued on as the model number should be on the front lower RH of the unit.
I am in the process of having an Alpine head unit fitted to our 06 V70 with a back up camera as it was not fitted with back up sensors ( the boss's demand!). I was considering doing it myself but the wiring for the head unit is more complex than I like to deal with and we have a good shop locally for installs. It has been delayed as the only bezel available looks naff as it has a large gap around the actual radio. I have ordered 2 others from Ali Express which should fit better. I'll check which is best when the 2nd one arrives hopefully next week.
The head unit is a full bluetooth unit with bluetooth streaming. It was bought on sale for $400 CDN (about $300). There are cheaper units out there and if you are not fussed about a back up camera they are cheaper.
Good luck!
jonesg
Post by jonesg »
priced as low as $85,
check yr and volvo model for facia adapter plate and plugs,
steering wheel controls might be lost, I could care less.
https://www.amazon.com/s?k=dbl%2Bdin%2B ... nb_sb_noss
