jimmy57
Been thanked: 320 times
Re: What did you do to your Volvo today? (now Sticky!!)
Post by jimmy57 »
Replaced rear control arm bushing on the RF lower control arm on my 2010 XC60 T6. Took care of the steering wheel shimmy upon braking at speeds. That is a hydraulic damped bushing and if they get oily and you have brake shimmy with no pedal vibration and no hole car vibes then the bushing is likely it. Benz and BMW have long histories of their control arm bushings doing this. I guess Volvo decided they needed a Euro luxury car wear item to compete with their peers.
jvl
Year and Model: 2006 V70 2.4D
Has thanked: 20 times
Been thanked: 8 times
Post by jvl »
Changed out rotten vacuum hoses for new ones.
The transparent one was put in 2 weeks/ ~1200km ago as a temporary fix untill new ones came in, and it already almost collapsed!
Garbage belongs in the waste bin...
1999 V70XC - Sold at 250K miles
2006 V70 2.4D - bought at 190k miles and going strong
cmblackburn
Year and Model: 1998 S70 T5M
Has thanked: 1 time
Been thanked: 7 times
Post by cmblackburn »
Finished the engine swap and got her running again :) Nice to have it back on the road, new engine has gobs of power and runs very smooth.
1994 855 Turbo, 243k "Honey Badger"
1998 S70 T5M, 287k "The Blue Turd"
2004 S40 2.4i, 197k "Cosmo"
2005 XC90 2.5T AWD, 207k "Apollo 13"
2011 VW Jetta SportWagen TDI 6MT, 93k "Zoe"
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 305 times
Been thanked: 517 times
Post by bmdubya1198 »
cmblackburn wrote: 14 Oct 2018, 13:27 Finished the engine swap and got her running again :) Nice to have it back on the road, new engine has gobs of power and runs very smooth. 43950410_10217505483809363_592902514177736704_o.jpg
Nice! What engine did you use, just the stock B5234T3?
Got my R running again today! Started right up, and it only has 3 codes! One for intake air temp sensor and the other two for lack of communication with the transmission (obviously...).
The car won't move unfortunately, but I think that's due to the passenger axle. The car still rolls when it's in gear, and only the driver's side axle is turning, so I think the issue is the AW55 pass. side axle that I reused. The driver's side AW55 axle seems to be just fine.
cmblackburn
Has thanked: 1 time
bmdubya1198 wrote: 14 Oct 2018, 16:32
It is a B5234T from a '96 855 Turbo that had been sitting pretty much buried in the dirt in a junkyard since 2011. Took a chance on it for $350, and I'm glad I did.
That's pretty odd, axle splines seated okay in the transmission?
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 337 times
Post by Chuck W »
Started messing with the PCV service on the '97 T5. It's been puffing a little smoke lately.
The previous owner said he had recently done a PCV service when I bought the car.
If by "service" he meant throwing hoses on there with no clamps of any sort, and not tightening all of the lower intake bolts, then OK, a service.
The parts as they came out of the car. Notice NO clamps, whatsoever. The drain ports into the engine looked clear, at least, but none of the hose fittings were tight/snug.
I'm doing the "high-mileage" mod, with the larger ID tubing and opening up the hole in the PTC valve a bit.
Not a whole lot of time to work on this, so I'm really not going to get to do clean any of that crud off of the block at this moment, unfortunately.
I am replacing a bunch of dead vac lines and IC couplers with silicone, though.
bmdubya1198
cmblackburn wrote: 14 Oct 2018, 18:21 It is a B5234T from a '96 855 Turbo that had been sitting pretty much buried in the dirt in a junkyard since 2011. Took a chance on it for $350, and I'm glad I did.
Nice, good deal!
The axle seems to be in the transmission fine, but it may not be seated in the wheel hub. I'm going to pull the wheel off again today and see what's going on.
I just realized that I won't be able to use the AW55 axle anyway since the outer diameter is a lot smaller and the axle seal will just pour out fluid. Out with the axle again... crossing my fingers the correct axle will allow me to drive the car now!
Has thanked: 1511 times
Been thanked: 3827 times
Great news. It is moving, it just SEEMS to stand still..
(back to you)
:lol: :lol: :lol:
bmdubya1198
abscate wrote: 15 Oct 2018, 09:16
(back to you)
:lol: :lol: :lol:
Yeaaaahhh... this situation isn't helping my argument :lol:
Farmed out my tie rod ends and FWA
I had a look at the tie rod and it was frozen, trip to BOS tomorrow, managed to drop car at local indie, wcm picked me up, and had car back by noon with two new tie rods and FWA for $90.
Have to say, it was worth it.
