xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
454cid wrote: 06 May 2024, 21:43
xanthefin wrote: 06 May 2024, 21:37
Replaced yesetrday then summer tires and driver side light and now i feel i need replace right side as its so different..
How did you end up with one North American DOT headlight and one European headlight?
I am now confused. Which one is American? Could explain something too :mrgreen:
The original driver side MOT last year did fail due it become too spreaded light which right side still has old too but it "barely" passed. It wont anymore make light pattern but makes just.. light bulb.
I might need adjust the new one still as its new thing for me and i had put electric adjustment there which took moment how moving worked. Though old timers sees in first sight what i dont.
Well higher up in seller / manufacturer in ladder tries confirm:
"All products are produced according to ISO 9002/TS 16949 certificates and environmental certificate ISO 14001. All lamps designed and offered in European markets have an ECE certificate."
Maybe i need just order other side to be similar and not decades washed out either.
wheelsup
Has thanked: 15 times
Been thanked: 20 times
Post by wheelsup »
Sveedy wrote: 06 May 2024, 17:16 This one got my attention. Surprisingly no major damage. Just a little pit.
On any newer car that would've resulted in a complete crack lol
Still on my original windshield, almost 30 years in.
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 131 times
Post by 454cid »
xanthefin wrote: 06 May 2024, 21:45
Now, when I enlarge the picture, I believe I was mistaken. I can see the lines in the glass better. Assuming left hand drive, it was the passenger side that I thought to be American spec. I apologize for causing confusion. Maybe the glass is pitted? Both look more yellow than I'm used to seeing, also. Do you have tinted bulbs?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 1511 times
Been thanked: 3829 times
It’s a NATO alliance car.
xanthefin
Post by xanthefin »
454cid wrote: 07 May 2024, 03:35
The passenger side (original -- hella) i agree is yellowish and has too lines in glass ( americans doesn't? new info for me ). The driver side is actually clear and no no i was confused already how much difference new one had. It makes car irl look like ten years newer due it and forcing me to buy passenger side as well now :wink:
Bulbs can have slight yellowish look. I had some night breaker lights years ago which were more white but i kept cheap bulb line ever since again.
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
The bright silver coating on the reflector gets dull and tired over the years, especially in places where the headlights are always on. There does not seem to be any other solution except replacement. Plus the car will look much happier.
454cid
Post by 454cid »
xanthefin wrote: 07 May 2024, 06:44 The passenger side (original -- hella) i agree is yellowish and has too lines in glass ( americans doesn't? new info for me ).
Our lights do have lines, but in a different pattern.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 305 times
Been thanked: 517 times
Post by bmdubya1198 »
Inspecting based on light pattern... meanwhile here, you'll pass inspection as long as there is light being emitted from the front end. Doesn't matter if it's a headight or a flashlight.
xanthefin
Post by xanthefin »
454cid wrote: 08 May 2024, 01:42
Ooh okay i see. Thanks for information i keep in mind this detail.
bmdubya1198 wrote: 08 May 2024, 08:09 Inspecting based on light pattern... meanwhile here, you'll pass inspection as long as there is light being emitted from the front end. Doesn't matter if it's a headight or a flashlight.
Ha! I need tell you then too that they here inspect even colour of your turn signal bulbs. If their yellow layer has been burned off (so its more white flash) you get fail notice on paper about it if they spot it. :mrgreen:
bmdubya1198
xanthefin wrote: 08 May 2024, 09:31
That is something that drive me nuts though! I hate seeing peeled amber coating on turn signal bulbs.
