Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
Installed new springy thingies on the V70, the BC racing coillvers became too harsh after 65k km and almost 5 years. Would have hoped for better longevity given the price...
bit of a bastard setup for now, used B4 I got from a parts car, new KYB rears and Vogtland springs (not expensive and i liked the color :mrgreen: )
Rear right doesn't sit at the same height as the left, hopefully it'll settle down after a bit because i cant see any difference between the two sides :shock:
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
crasbe
Year and Model: 02 S60, 98 V70 (EV)
Has thanked: 31 times
Been thanked: 79 times
Post by crasbe »
Today the second part of the carpet voyage followed.
Unfortunately the rubber mat was hacked apart and worn as well before installing the carpet.
The previous owner decided to "fix" it with painters tape which obviously didn't really work. Therefore I got a roll of Siga Rissan, that is usually used to tape and seal moisture barrier foil. It sticks like crazy.
The center part of the rubber was crack-y as well, so it got a layer of Siga Rissan as well:
Now the footwell is nice again :D
I'm so happy to have this done. Now I can get back to making the car electric :D
Check out my 3D Printed Parts for Volvo P2 and P80 on Printables :D
Has thanked: 1856 times
Been thanked: 1718 times
You just need to print a foot rest and then you are done!
crasbe
Post by crasbe »
scot850 wrote: 08 Jul 2024, 16:06 You just need to print a foot rest and then you are done!
I have the footrest, it's just not cleaned yet :)
manovlov
Has thanked: 620 times
Been thanked: 143 times
Post by manovlov »
I've replaced 2 broken fuses 10 A. The side indictor on the left winng broke, the + went to the car's body and dashboard light off.
Manov
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 68 times
Post by jsrnsis »
Lined up
Lined up
This side sits flush with the taillight.
Not lined up
Not lined up
This side doesn't.
I tried moving the bumpers at the lower corners of the tailgate, but it made no difference.
I spent today replacing my tailgate latch/lock since the previous owner destroyed it by slamming the tailgate instead of replacing the striker plate that was missing the plastic/rubber band.
I proceeded to snap off the tailgate interior panel (that was never loose and rattly) and found out it had previously been repaired with a kit, then the kit removed and the clips held in place with cotter pins. I should have taken pictures as it's hard to explain. Pry off the bottom of the trim, and then the top should just slide out...
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
Oro
Year and Model: V70 XC, XC70+S60 awd
Has thanked: 7 times
Been thanked: 37 times
Post by Oro »
crasbe wrote: 09 Jul 2024, 03:13
Hey - I looked at your printables and that’s really neat. I’d love to get the light clip and bushing tool (wish I’d had them in the past!). I know nothing about 3d printing (well, only the very basics - made one simple thing in a class once). I want to make a replacement actuator for the rear hatch lock on 99/00 wagons. I know what the issue is and how to fix it; just need to learn how to model the part and print. Would save a lot of people spending $250 on replacement locks!
Oro
Post by Oro »
Slowly getting my exterior detailed after long neglect. Today I refinished the lower body cladding and door strips with boiled linseed oil. I’ve done this before and it looks great and lasts a LONG time. Only downside is it takes a long time to dry, so I stuck the car in the garage for the weekend.
The “before” picture is misleading; it looks MUCH worse in person.
Before (looks worse IRL):
After:
BlackBart
Has thanked: 928 times
Been thanked: 885 times
Post by BlackBart »
manovlov wrote: 10 Jul 2024, 13:13 I've replaced 2 broken fuses 10 A. The side indictor on the left winng broke, the + went to the car's body and dashboard light off.
Manov
Good to see you here, Manov.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 305 times
Been thanked: 517 times
Post by bmdubya1198 »
Oro wrote: 12 Jul 2024, 19:42 Slowly getting my exterior detailed after long neglect. Today I refinished the lower body cladding and door strips with boiled linseed oil. I’ve done this before and it looks great and lasts a LONG time. Only downside is it takes a long time to dry, so I stuck the car in the garage for the weekend.
After:
Linseed oil works really well on the plastic trim!
