Has thanked: 1511 times
Been thanked: 3829 times
Re: What did you do to your Volvo today? (now Sticky!!)
abscate wrote: 07 Jan 2019, 11:44 Got Evita the new V70 S70 into the garage and evaluated seized engine. Started a maintenance thread to record for now. If I make good progress, Ill create a 'how to recover a seized engine thread"
Sneaked out into the garage over lunch and the potion has dropped! I will try spinning the crank pulley tonight. Have to work in NYC tomorrow, if I am lucky I will take Friday and see if I have a runner!!!
Irish bookmaking odds are now up to 50-50 on Lady Evita Recovery
From my maintenance log (Optimist)
Evaluation of motor this weekend.
Got 30mm socket on crank pulley - I can feel crank turning and resistance in pistons. I removed starter and confirmed that the flywheel is moving slightly, but then I put Pooh sticks into all cylinders, 1-4 move but number 5 is stuck firm.
Gentle pressure on pistons confirms movement in 1-4, none in 5
Borescope in 5 unremarkable.
Ive got a feel I have stuck ring in the bore.
Added MMO/diesel/acetone in a proprietary mixture, known only to MVS, to Cylinder 5.
Planned strategy - give it a week soak, then see if I can break it free and retain compression.
A well working MM ETM body will be sacrificed to Odin, God of Volvo this week for compensation.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 305 times
Been thanked: 517 times
Post by bmdubya1198 »
abscate wrote: 09 Jan 2019, 14:02 Thats another 10 laps for me and June...and Im going to be driving Evita - Dont cry for me....
You better throw some nitrous on that thing if you plan on passing any car!
abscate wrote: 09 Jan 2019, 14:05
Quick update. Houston, we have rotation. Cylinder 5 has freed up. I hope to see if I have a runner by end of weekend. They make these engines tough.
bmdubya1198
abscate wrote: 09 Jan 2019, 19:25 Quick update. Houston, we have rotation. Cylinder 5 has freed up. I hope to see if I have a runner by end of weekend. They make these engines tough.
Well done! Hopefully you'll get lucky and it will have good compression on all 5.
Have to jump to NYC today but might take Friday morning to try the starter and listen to the top end for expensive noises
I guess a cold compression would also be a good check but honestly I’m told by the gurus if it freed up chances are high the top end is good.
So next steps...
Spinup test
New plugs
Fire it up
Warm it up
Oil change
Test drive
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Wife said there was horrific noise from engine when it occurred (which I just learned of last night), but that she shut down immediately on hearing same.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
I think she saved it, nice.
I owe my favourite attorney $10 in spare change he left me in the glove box too.
E Showell
Post by E Showell »
Spouse and offspring all thoroughly instructed to shut down immediately on both any increase in engine operating temperature and expensive sounding noises.
'95 855 auto (sold)
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
abscate wrote: 09 Jan 2019, 14:05 A well working MM ETM body will be sacrificed to Odin, God of Volvo this week for compensation.
Why Odin? ... Eir is the goddess of healing.
Damn. Does anyone have another ETM?
