Vida CEM swapping
vtl
Year and Model: 2005 XC70
Has thanked: 115 times
Been thanked: 609 times
Re: Vida CEM swapping
Post by vtl »
RickHaleParker wrote: 09 Feb 2022, 07:36
vtl wrote: 09 Feb 2022, 07:32 The problem is CEM P/N 8690720.
8690720 will not crack on 0 or 2?
Nope. Shuffle order is 2, as confirmed by disassembler, however it still does not crack.
viewtopic.php?p=592875#p592875
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
vtl wrote: 09 Feb 2022, 08:03 Nope. Shuffle order is 2, as confirmed by disassembler, however it still does not crack.
Has his dump been run on different hardware?
Anybody check out his cracker build construction?
vtl
Post by vtl »
RickHaleParker wrote: 09 Feb 2022, 08:56 Has his dump been run on different hardware?
This is CEM problem, not his cracker. I've got a similar report from other person.
RickHaleParker
vtl wrote: 09 Feb 2022, 09:26 This is CEM problem, not his cracker. I've got a similar report from other person.
I got got reports from two others, one of which has two 8690720s.
We can bring the total of 8690720 that will not crack up to a count of 4 + your reports if they are from different people.
vtl
Post by vtl »
Despite the pin was not found, see how average response latency drifts right with every new position:
Code: Select all
13:19:33.232 ->                    us:   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156
13:19:33.232 -> [ 91 -- -- -- -- -- ]:     1  6952     0 16051     1 14549     0   674     0     0     0     0     0     0     0     0     0     0     0     0 : latency    5610230; std 1678.65
13:28:09.457 -> [ 91 95 -- -- -- -- ]:     0   107     0  1026     1  5562     0 15318     0 17172     0   809     0     0     0     0     0     0     0     0 : latency    5781523; std 1754.15
13:36:45.684 -> [ 91 95 89 -- -- -- ]:     0     0     0    18     0   277     0  2373     0  8916     1 16696     0 11203     1   510     0     1     0     0 : latency    5915132; std 1622.53
Apparently something is going on in the CEM code, the pin compare routine executes longer. Which makes me think it is still crackable, just don't know how yet. I would say, shuffle order is wrong, but AA2020 shared his CEM dumps and I found the code, and now we know what the shuffle order is for this P/N.
Hmm...
vtl
Post by vtl »
AA2020 wrote: 09 Feb 2022, 04:56 The order is 5, 2, 1, 4, 0, 3. Could you try it with shuffle order set to 2?
Not working.
https://github.com/vtl/volvo-cem-cracke ... r.ino#L645
Can you try replacing random(100, 255) with random(0, 99) in that line?
AA2020
Year and Model: 2007/ V50
Post by AA2020 »
P1_Shuffle_012345_Not_OK_03.txt
(143.39 KiB) Downloaded 114 times
P1_Shuffle_521403_Not_OK_04.txt
(143.12 KiB) Downloaded 80 times
sirloins
Year and Model: 2010 V50 T5 AWD M66
Been thanked: 3 times
Post by sirloins »
It looks like I have both the 719 and 720.
A while back when Rick asked me to try his changes I thought I had damaged my hardware, but in reality, I had swapped in the 720 CEM which others have had issues cracking.
The code seems the same, I followed it at least from the function that calls the PIN verification code. I am not too much of a hardware guy and at first glance, the boards look the same, same can transceiver as well. If there are some ideas to check from a hardware side let me know.. I have already separated my CEM boards so they are just the CPU boards now.
vtl
Post by vtl »
sirloins wrote: 12 Feb 2022, 16:02 It looks like I have both the 719 and 720.
What CEM P/N did you crack initially when you've added P1 support? I've unified the code base awhile ago, based on testing with newer P1 CEM I have, and it's not unlikely older one is regressed.
sirloins
Post by sirloins »
Originally I was using a 8690719. I think when I last tried the code (over a year ago I think) I was using the 8690720 CEM.
I will be getting both of those CEMs wired up again to test with.
