97 850 t5 Not starting and flsashers going
mcbeav
Year and Model: 850 t5 wagon 1997
Post by mcbeav »
My wife went out to start our 1997 Volvo 850T5 Wagon. It would not crank at all. I came out and the four way flashers were going. The code light on the radio was on as if the battery was unplugged. I tried to jump it from our other car and the starter would not crank. Any ideas?
Thanks
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1245 times
Post by matthew1 »
Sounds like the alarm was tripped and it's still in alarm mode.
From the outside, lock/unlock car.
Then try to start it normally. If she doesn't fire, it's a dead battery issue from that point forward, and you should proceed from there.
Also -> Amazon link
mcbeav
Post by mcbeav »
That is where I was leaning towards. The battery is low on juice so I will wait until my other car gets home and try and jump it. One thing that it did do is cause my faulty clock to start working and not resetting itself. I will see if that lasts.
Thanks
mcbeav
Post by mcbeav »
Jumped the car and it starts. Battery is not being recharged after driving for over 1/2 hour. Clock is still resetting itself. The battery checks out as fine but low. Alternator is putting out but according to the test , just above the minimum. Should I have them recharge the battery completely before trying anything else?
matthew1
Site Admin
Post by matthew1 »
You need a new battery, if I had to guess.
Also -> Amazon link
9394volvo850s
Year and Model: 93 850 5spd 94 850T5
Post by 9394volvo850s »
mcbeav wrote:Jumped the car and it starts. Battery is not being recharged after driving for over 1/2 hour. Clock is still resetting itself. The battery checks out as fine but low. Alternator is putting out but according to the test , just above the minimum. Should I have them recharge the battery completely before trying anything else?
sounds like the alternator is bad if its just above minum. get a new one.
93 850 5spd 320k (the daily)
94 850 T5 190K (race car)
95 T-5R wagon yellow (summer wag)
90 745 5spd 295k (winter wag)
67 122 2 door 4spd 69k :))
mcbeav
Post by mcbeav »
Tried to have the battery recharged and it did not after a couple of hours on the charger. Retested battery and found it was bad. Went and bought a new battery and everything is fine now except the clock keeps resetting itself. The funny thing is the battery was new in Feb. Because I bought the battery with the car, the Autolite distributor would not warranty it.
Thanks for thehelp
