Vibration at High Speed
Timmah108
Year and Model:
Post by Timmah108 »
Hi All,
I am noticing recently that when I go 65+ mph my car starts to vibrate and progressively gets worse the faster I go to the point that at about 80 mph the car is vibrating violently. Additionally if I am in a turn at that speed the vibration either subsides or goes away but once I go into a straight away the vibration returns. It seems to have begun after I changed my struts and before I got a wheel alignment. I thought the wheel alignment would fix it but it is still there. I have looked around and it seems people with similar situations the remedy varies from the tire to the axle itself. I am wondering if anyone has come across this and how they fixed it. Any help would be appreciated.
Thanks,
Tim
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Do your brakes shimmy violently if you apply them at higher speeds?
'98 S70 T5
2016 Chevy Cruze Premier
Timmah108
Year and Model:
Post by Timmah108 »
I don't believe so. Also when I am not pressing on the gas pedal the bibrations seem less.
ctriordan
Year and Model: 1999
Post by ctriordan »
Had the same problem, as well as a clunking noise when turning left. Turned out to be my sway bar end links. hope this helps
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
I had a similar issue. When I got to 90mph my car would shake like crazy. An alignment fixed everything. When you had your alignment done did they do all 4 wheels?
micah861
Year and Model: 98 S70, 98 S70 T5M
Post by micah861 »
being as im a tire man, thats usuall the first thing i blame. a. any unusual tire wear? b. hit any potholes (that can cause you to kick a wheel weight. c. had the wheels balanced recently?
Red 98 S70 T5M
Black 98 S70 N/A
