[quote="MadeInJapan"]No, it's not the same...actually there is a transmission speed sensor which causes the engine to run at different speeds as well as a Vehicle Speed Sensor...I'll post both fixes from VADIS below:
madeinjapan, i'm assuming the vehicle speed sensor has anything to do w/ the faulty gearbox problem in this thread?
850 automatic transmission Topic is solved
Classic PNP Switch Shifting Fix
milesursogood
- Year and Model: 850 T-5, 1997
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
I don't have a clue- the thread is over 2 years old- I'll go back and re-read....
I used Lucas transmission fix and after a week the problem is largely solved. This allows fluid to leak aroung the seals and increases the time for the pistons to lock the clutch.
There are a number of products that may work just as well. I am angry with myself
- 1166 Views
Last post by Krons
- 1428 Views
Last post by tmmaida
- 1664 Views
- 1583 Views
Last post by jimmy57
- 1522 Views
Last post by SuperHerman
