740 GLE transmission problems
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
onderdonkjm
Year and Model: 1992 740 GLE
Post by onderdonkjm »
i was travelling on the freeway moving right along when all of a sudden i lost all forward motion. engine runs strong but vehicle will not move at all in forward or reverse. please help, i love this car
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Is the transmission manual or automatic?
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
onderdonkjm
its an automatic transmission, sorry so late in replying
billofdurham
Assuming the drive shaft is still attached at both ends it would appear that the box has developed a fault.
The first thing to check is the fluid level and condition. If the fluid is brown and smells of burning it needs to be changed. It should be red with no smell. If the colour/smell are OK but the level is low top it up and see if that cures the problem. The transmission fluid should be changed every 20,000 miles (32,000kms) on your car.
The attachment shows the possible faults that could be causing this. Unfortunately, apart from top up/flush; blocked strainer; shift linkage and kickdown cable adjustments you need specialist equipment.
740 auto box no movement1.pdf
(241.98 KiB) Downloaded 216 times
Bill.
Previously:
onderdonkjm
Thank you so much for your help, I will be checking it soon!
Reason: Reduced from all capitals which equates to shouting.
