Transmission mode "W" Blinking
This topic is in the MVS Volvo Repair Database » Simple Volvo Tweeter Modification
Adrian
Post by Adrian »
Hello Everyone,
I need some help with this problem.
Today the mode "W" engaged warning lamp started to flash. I would like to know what can be the possible causes to this problem and how can I solve it.
Thank you.
Adrian
Post by Adrian »
Sorry..!
I have a Volvo 850 GLT 1993
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1254 times
Post by matthew1 »
W means you're in Winter mode.
So you were driving in Winter mode, and the transmission "up" arrow warning light came on?
Also -> Amazon link
Guest
Post by Guest »
Matthew,
I am not driving in winter mode. I checked the manual that came with the car and it is says that the light is going to come on in that case. My case is that the arrow light is flashing even though I have not changed the thing to a winter mode. According to the manual, the flashing arrow indicates a problem with the gear box. The weird thing is that the gear seems to be shifting properly ( it is my impression ) because of the sound the car its making when I am driving.
PD.
This night I just came back from work and the light went off. However, I am still worried that it is going to happen again. I do not know what could it be.
matthew1
Site Admin
Post by matthew1 »
You need to check your codes to find out what error the car is recieving.
Also -> Amazon link
Tsquared
Year and Model: 11 C30
Post by Tsquared »
When was the last time the tranny was serviced?
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
TNStangman1
Post by TNStangman1 »
Its your PNP switch.
Guest
Post by Guest »
TNStangman1 wrote:Its your PNP switch.
What is the PNP, I have the exact same problem, only in my car (94' 960) it happens at least once every week and when it does the car runs very slow. What I do is turn the switch off and then back on a few times then the light goes off and then I can drive it normaly. Just to make sure, this happens with out me pushing on the W mode.
ThanX
94"960
[email protected]
