N/A tuning 20V, VVIS, something diffirent.
Improve Air Delivery to N/A Engines w/ VVIS Mod
tjts1
- Year and Model: 96 855 NA 5 speed
- Been thanked: 4 times
Does the car you did the modification to happen to have a trip computer to give you real time fuel economy? I would be curious if its move efficient with just the long or both long/short intake turned on. I could see having VVIS setup with a switch in the dash. Both runners open for FE, and just the long runner open for power at low RPM.
Ambitious but rubbish
razorx
- Year and Model: 855 '96, 854 '93
I am still wondering.renns wrote: Very nice work! I wonder why Volvo chose to configure the system in the way they did?
The best description is the official Volvo one, in my first post.renns wrote: What is the normal state of the VVIS valve? If it's normally in the closed position, I suppose one could test the low-speed improvement by simply unplugging the actuator?
Very short description:
Always both channels open, except when below 4100rpm AND more than 80% throttle opening.
When you accelerate the original system will only give you wat you need with more than 80% throttle, and to late.
In some earlier tests we logged the AFR. It is still round the 14,7.renns wrote: Did you happen to log air-fuel ratio for the runs you posted earlier? Does the stock ecu correct automatically for changes in the changes in volumetric efficiency?
The stock ecu ccan handle this. A very important question b.t.w..
I believe I tested my idea by unplugging the connector.
Not 100% sure.
razorx
The modified car has a trip computer.tjts1 wrote:Does the car you did the modification to happen to have a trip computer to give you real time fuel economy? I would be curious if its move efficient with just the long or both long/short intake turned on. I could see having VVIS setup with a switch in the dash. Both runners open for FE, and just the long runner open for power at low RPM.
With quiet driving the economy improves a little bit.
If you enjoy the system, the economy worsenes.
The switch I only used for testing purposes.
0 means Volvo system
1 means my system, which opens de schort duct automatically above 4100rpm.
- RobTheModd
- Year and Model: 98 S70T5M
- Has thanked: 5 times
- Been thanked: 7 times
*cough cough* when can we get our hands on this.
as i have a 96 850 GLT id love to try it out. providing its not going to damage the car lol.
- Has thanked: 2866 times
- Been thanked: 1332 times
Razorx,
Please continue to use this website as your bullhorn regarding your research and product.
I do not consider this advertising at all. On the contrary, this is super information for N/A owners.
Please continue to update us about your research, and your plans to make this a product.
razorx
Sorry for the delay, yust soldering some circuit boards.
@Matthew: Thank you, I yust sent you a PM to be sure.
Well, after a year of serious testing, with multipe engine versions. MT/AT LPG/Gasoline, AFR e.t.c. I can only say it is a ready and well tested product.
If somebody is interested, please feel free to send me a PM.
At the Dutch Volvo 850 forum, http://www.volvo850forum.nl another person has started a very interesting topic about low budged tuning.
This is not as easy as my mod and involves some craftsmanship.
(Manifold matching). Lot of work b.t.w., but interesting.
I will inform you when there are the first results.
Kind regards,
Y.
Kind regards,
Y.
razorx
Good morning,
mck1 has helped me a lot working on the manual. I dared to change a few things.
Please read it well, my native language is not English:
http://www.paerl.it/volvo/vvis%20manual%20eng.pdf
Is this clear enough?
Kind regards,
Yits.
Kind regards,
Yits.
- 4749 Views
Last post by TheMrFailz
- 9 Replies
- 1811 Views
Last post by dikidera
- 1686 Views
Last post by Clemens
- 2224 Views
Last post by precopster
- 25 Replies
- 5305 Views
Last post by razorx
