I drove into a 8" granite curb stone -thanks MDC- while perpendicular parking and cracked that plastic, umm, shield/cover thingy under the front. It is bolted to either side of the subframe (I think) and the plastic broke about a half-inch from the bolt on the passenger side. I removed it easily enough so I could drive home, but now that New England has plunged into snowy, salty, grimy spray and even-more-broken pavement season I want to know what it is called (or a part #) so I can go to a junkyard and get a replacement.
The plastic is sturdy enough that I can drill some holes in the broken end and wire it to the bolt, which is good enough for local, but I'm afraid it'd drop out driving at speed. Thanks, Oliva77 of Concord NH
1998 V70 Name of plastic shield under the front
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
I did the same thing, went too far up over a curb and tore it off. I fixed mine like that for a good 6 months and it was fine on the highway until I went over a speed bump too fast and tore the whole thing off.
It's called the air guide, here is the part for it:
http://www.fcpgroton.com/product-exec/p ... +Air+Guide
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
Yes, it is the same.
'98 S70 T5
850Platinum503
- Year and Model: 1996 850GLT Platinum
thank you jblackburn, appreciate the name of this thingy, I can order one thru Matthew's Amazon link for my 1996 GLT
