240 1986 heater blower squawks at me!
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Jeff1964
Year and Model: 240DL 1986 >268k
Post by Jeff1964 »
Okay, it is cold here, and I need to run the heater- however I get squawking from somewhere in the blower assembly. When I run the heater on the highest velocity, the squawking goes away and I can then return to level 2 and it is fine. Seems that the heater motor itself is okay. Is there someplace that needs a shot of silicon spray? Is the motor directly attached to the impellers? This happens in the summer as well when we are running the A/C.
thanks and Merry Christmas,
Jeff
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
The motor is attached to the impellers.
Unfortunately, on the 240 getting to the motor is a major job, even to give the bearings a squirt of silicone based oil.
This link will take you to a site that deals with this problem. Make sure you also read the 'Chainsaw Method'.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Jeff1964
Post by Jeff1964 »
Hi Bill-
I visited the page you mentioned and had seen it before but did not want to take the plunge..
Well on Christmas Eve I jumped in the deep end for about a half hour and started the tear down and on Christmas Day (after the presents) for another couple of hours I got to taking the motor out. The bushings were fine- just dry as a bone. I smeared a bunch of bearing grease on them and squirted some silicone lube and paraffin-based bicycle chain lube as well. Remounted the motor and tested it- no more squawking!
Saturday morning, 28 degrees in the garage, and four hours later everything was back together. My hands were thawing out around dinnertime. Next time I'm using a heater! :shock:
Now my flapper controls don't work because I routed the tubes wrong and plugged the left vacuum tube into the top left flapper control. Somehow I lost that tube in the process.. But we'll sort that out soon- at least its quiet when the blower is on.
Thanks for the tip :lol:
Happy New Year!
Jeff
billofdurham
Thank you for the update.
Bill.
Previously:
