Thinking about buying an 850 that needs a new engine
wheelsup
- Year and Model:
- Has thanked: 15 times
- Been thanked: 20 times
Just curious if I buy it would anyone like to help me (via the internet) create a DIY w/ pics for replacing the engine? I am thinking about buying it but have never done such a large job before, so I would need help, but would also like to document it.
1995 850 GLT Wagon w/ 200,000 miles
- phils94850
- Year and Model: 2009 s60 turbo
If i was closer id help, i think it would be great to have a step-by-step on motor replacment..
1996 Platinum Edition
- RobTheModd
- Year and Model: 98 S70T5M
- Has thanked: 5 times
- Been thanked: 7 times
1. better not be paying over a grand for the car...
2. idk id just make sure all the holes have things plugged into it when i put it in. im sure you can find one somewhere.
did you try the repair database,
or even try over at Volvospeed
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
I've never done an engine swap myself, but I'd like to help you along in any small amount I can. Even just documenting and doing a write-up if that's what you need help with.
I'm in and out of Durham every 2 weekends or so - if you actually decide to go ahead with this, I'd be glad to stop by and help!
'98 S70 T5
2016 Chevy Cruze Premier
wheelsup
- Year and Model:
He wants $300 for the car. If the interior is in decent shape w/ relatively low miles (ie not over 150k or so) I might buy it.
The engine seized when it ran out of oil. Said it had a "larger leak than I thought". Sounds like a RMS. Anyway the engine itself is toast so no rebuilding. This might be fun. The exterior looks decent, if anything I might buy it and take off the spare parts like the MAF, fuel pump, etc. etc. and let a junkyard have it after that.
C@lvin
- Year and Model:
- Been thanked: 2 times
This is exactly what I'd like to do and have considered. So far, I haven't taken the leap because either 1) Time, 2) Money, and 3) I don't have a good place to do the work at my house. If you decide to do it, I will definitely follow your exploits and help in any way I can though I've never done anything this extensive before.
I do have a Harbor Freight coupon for a 1 Ton shop crane for $99.99 ("reg" price of $179.99) that I can send to you (it says it's valid until 02/20/10) and I got a flyer in the mail yesterday that had their 1 Ton engine stand for something like $39.00. I don't know how useful the engine stand would be, but I wouldn't want to try to do an engine swap without the crane....PM me if you want the coupon.
Good Luck!
Good Luck!
Calvin
98 S70
00 V70
240,245,760,940,850 Turbo
98 S70
00 V70
anmartin44
- Year and Model: 1994 850 n/a
- Has thanked: 2 times
it's funny you bring this up cause i have a 94 n/a that's sitting and waiting for a new engine. i bought it in december 08 hoping to get to it in the summer...yeah right. but it has 150k and the same MO as the one your looking at. owner ran it out of oil and seized it up. has brand new stereo and everthing work electrically. i'm am supporting you 100% to do this project for selfish reasons! i'm hoping to do mine this summer.
good luck and i hope to help out if i can.
andrew
andrew
1994 850 na green 187k on body, 275k on motor(backwards?), unrestricted airbox, 960 TB, persus wheels, Lowered, IPD poly upper and trans mounts.
1974 144 k-jet m40 satin black, 250k on body, 25k on rebuilt motor(running...usually)
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Definitely go for it. Anything I can do to help I will!
- RobTheModd
Hey your in NC! do me a huge favor.. if you go to part it out let me know. and def let me know the color of the exterior.
I did an engine/tranny swap on my '94 shortly after purchasing it. The hardes thing about it was the bloody wiring harness with the bolting up of the A/C unit a close second ( I had unbolted it and let it hang to avoid discharging it). It is a tight fit on the way in and out but I was able to do it myself in a weekend. Only to find the new set had a rear main leak so I had to split pull it back out and fix that the following weekend..
- 9 Replies
- 1909 Views
Last post by j-dawg
- 1742 Views
Last post by precopster
