This is timely. I'm going to do the same thing because my PCV system is completely clear yet still smokes.
When I pull the dipstick out I get practically zero leakage from the RMS.
Supplemental PCV system?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
This is awesome! If I can't figure out why mine still smokes, I might rig up something like this for mine too. Thanks!
'98 S70 T5
2016 Chevy Cruze Premier
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
How does this "relieve" the PCV system? Aren't you simply collecting the white smoke in a jar instead of the engine bay?
tblindt
- Year and Model: SPORTSWAGON 855 1994
That is really cool alternative, does it really act like the original? anybody have picture or step by step process of PCV overhaul available? I'm assuming its not a hard repair.
1994 Volvo 855 Sportswagon 185k
It relieves the pressure out of the dipstick tube, combines with the factory PCV vapor canister output (with the brass tee), then collects the moisture/vapors in the jar then sends the gases back to the flame trap housing (without the flame trap) and into the intake minus oil dropletspolskamafia mjl wrote:How does this "relieve" the PCV system? Aren't you simply collecting the white smoke in a jar instead of the engine bay?
The factory PCV is probably still venting but with much less efficiency, That's why it's a supplemental rather than replacement of the factory PCV system.
Wagon Brigade >> 94 855 NA | 97 Subaru Impreza OBS | 07 Suzuki SX4
Previous Bricks >> 90 240 GLE 2.0 | 98 S70 T5A 2.0 | 03 XC90 T6 2.9
jblackburn
This is the process I followed for my turbo model:anybody have picture or step by step process of PCV overhaul available? I'm assuming its not a hard repair.
http://www.lakesidedp.com/uploadpics/pcv/index.html
The setup for an N/A model is slightly different (mainly the flame trap), but you will be able to tell from the PCV diagram what parts are different.
'98 S70 T5
Any oil in your catch can? I'm tempted to use a catch can with a breather filter on it rather than rerouting back into the intake for my "off road use only." I've changed out the PCV and still have smoke from the dipstick. This could save my seals before it is too late.
'94 855T Wagon (120K)= Boost and a booster seat all in one.
Stage 0 in progress...
polskamafia mjl
Ok, I got it now.
Thanks a lot.
Update, it's been 2 weeks of driving around town with the peanut butter jar/catch can setup, it caught about 1/3 jar worth of liquid, mainly condensation and some oil. My garage smells of oil vapor because the tubes into the jar are not air tight, I'll need to think about a more permanent containment device
here are some photos:
Jar with steel wool, notice the level of condensation at the bottom.
Steel wool removed, they soaked up quite a load of fluid!
Ironically, the fluid has color like peanut butter
- 16 Replies
- 2295 Views
Last post by polskamafia mjl
- 37 Replies
- 7219 Views
Last post by tourspin69
