Hi all,
Has anyone ideas.
My temperature has stopped reading, it was working until the car got warm then the guage showed cold, no its showing cold all the time i.e not moving.
thanks
Oldskiddy
Temperature Gauge
If you loose the connection at the sensor and touch it just quickly to ground, the temp gauge should increase rapidly to hot. Note, just short test for a second or two!!!!!! If you want to test it more profesional, use a resistor of 68 Ohms = 75% gauge meter position ( boiling temp.).
The sensor is not really expensive, I think I had to pay 50 USD for the origin.
