I had to take the door panel off to lift the window manually so the interior would not get wet.
I understand that you can take the switches out of the center console and clean them but I could not get it out at all...damaged the plastic a little trying...is there a special trick? This is what the panel looks like...I was using a screwdriver to try and pry it out but no success.
Does the whole center panel have to come out? How do you do that?
