While changing the trip computer today, I ruined one of the dash speakers. I accidentally touched it and it disintegrated.
Is there any issue if I replace them with 4ohm speakers?
And thanks to DW Volvo for giving me my radio code. Unbelievably nice and helpful people.
-os
Dash Speaker Replacement
Volvo 850, S70, V70, C70, XC70 Dash Speaker Replacement
1996 850 GLT 262k miles (gone
1999 Honda Civic (gone)
1996 850 GLT (gone, no more Volvos
2000 Buick Park Avenue (gone)
2005 Honda Odyssey (gone)
2013 Lexus ES350 (replaced Volvo 850)
2021 Honda Pilot
2021 Honda Pilot
- Year and Model: Many Volvos
- Been thanked: 76 times
No.Is there any issue if I replace them with 4ohm speakers?
I have used Infinity 3.5 inch speakers - I think they are model number 3.5 cs. They don't bolt in as original but they work fine. The magnets fell off of my oem speakers in most cases.
Here is how I bolted mine back in and I unsoldered the factory harness from the OEM speakers and then soldered it back to the replacement speakers:
I left it with one bolt and all is good for me and mine. I did the same thing in my son's 850 and he cranks it to "11" - especially when he had a broken exhaust manifold.
Thanks! I saw your write-up last night an ordered a pair of those Infinities for $28 new last night.Ozark Lee wrote:No.Is there any issue if I replace them with 4ohm speakers?
-os
2021 Honda Pilot
2021 Honda Pilot
what I did was call volvo and saab dismantlers and had them send me some original equipment, i think they were 5 or 10 bucks. yeah, they're the same junky speakers, but easy to deal with. I hate the thought of fitting aftermarket stereo stuff (spent too much time hacking dashboards and doors in my youth
looks like those infinities fit well though.
Speakers arrived safe and sound.Ozark Lee wrote:No.Is there any issue if I replace them with 4ohm speakers?
They came with a pair of 100 uF capacitors. Did you use these?
-os
2021 Honda Pilot
2021 Honda Pilot
Yes, the new speakers are coaxial and the capacitors provide a filter for the tweeters.
Ozark Lee wrote:Yes, the new speakers are coaxial and the capacitors provide a filter for the tweeters.
Thanks!
-os
2021 Honda Pilot
2021 Honda Pilot
tblo760
- Year and Model: 760 GLE 1987
Substituting speakers is no problem,just make sure the impedance is correct,and polarity is observed,never replace a speaker that is rated lower than the original,this can damage the Amplifier IC.eg; if 4 ohm speakers are fitted,2 ohm speakers will be bad,if 8 ohm speakers are used they will not cause damage but will lose performance.If you can,check the resistance of a known good speaker,and try to match this.test with a multimeter and you will see the rating allthough there may be a slight variation depending on the resistance in the leads.To check the polarity of a speaker that is not clearly marked,connect a 1.5 volt battery across the speaker terminals,if the cone moves 'inwards'then the polarity is right,if it moves outwads then you have connected the battery the wrong way round.
The way of the wicked is as darkness,they know not at what they stumble,(That's why I'm here to help)
iselloil
- Year and Model: 1999 V70 XC AWD
A little note for the 99 v70,Crutchfield and other companies says they have no listing of any speakers that will fit front door. The infinity 6.5 shallow mount will fit using the factory speaker bracket just fine.You have to seperate the mounting ring from the stand off bracket,and then all if fine.
1999 V70 XC
1999 V70 under constuction,or
destruction from previous owner
Mobil 1
K & N Filters
Ceramic brakes
Mobil 1
K & N Filters
Ceramic brakes
- 984 Views
Last post by Paul-93-850
- 1296 Views
Last post by rasense
- 578 Views
Last post by Ozark Lee
- 724 Views
Last post by gordo850turbo
- 1270 Views
Last post by JRL
