S40 timing belt- crank bolt?
1996 - 2004 S40
1996 - 2004 V40
AlanS
Year and Model:
Post by AlanS »
2001 S40- The instructions say to remove the crank pulley with an impact driver. I do not have any power tools. Should I now forget to attempt this job? Is there a 'go around'?
nfeliz
Year and Model: 2000 S40
Post by nfeliz »
You can use a chain wrench around the crankshaft pulley to keep it from moving. This link shows a picture of it.
http://www.sears.com/shc/s/p_10153_1260 ... 921x00003a
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
AlanS wrote:2001 S40- The instructions say to remove the crank pulley with an impact driver. I do not have any power tools. Should I now forget to attempt this job? Is there a 'go around'?
I'm not sure if this applies to your car, but scroll down in this thread for directions on how to make a tool to hold the pulley while you loosen the nut with a socket wrench: https://www.matthewsvolvosite.com/forums ... 61#p114461
