showell,
It sounds like you either have a dead spot in the starter or a bad connection somewhere.
Have someone turn the key to start while you smack the body of the starter. If it starts, then the starter has a dead spot and needs replaced..
V70 '98 FWD, NA, 5 Speed -- Won't Start
- phils94850
- Year and Model: 2009 s60 turbo
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
Were the lights coming on on your dash?E Showell wrote: Would not restart -- same as recently, no solenoid click, no nothing. Just would not crank. This was in the early Spring maybe 40 degrees out.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 111 times
In the recent episode all dash lights were coming on fine.
In the prior incident it was so long ago, I don't recall.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
A loose ground connection could be the root of all your problems if it's something you haven't checked.
Or try what Phil suggested with the starter, hitting things always helps to take out frustration
'98 S70 T5
2016 Chevy Cruze Premier
- E Showell
How would I go about systemically tracing a loose ground? Electrical stuff is about my weakest suit. Guys start talking about continuity and resistance and my eyes glaze over.
'95 855 auto (sold)
'95 855 auto (sold)
jblackburn
And that's exactly why I quit engineering and decided I wanted to be a teacher and make maps instead. Well, that and the really hard math.Guys start talking about continuity and resistance and my eyes glaze over.
Fortunately, you don't really need to worry about any of that. Just follow the negative battery cable to its ground on the chassis (usually under the battery tray), and clean up and tighten the negative terminal on the battery, and make sure its bolted securely to the chassis.
It wouldn't hurt to check out the positive ones leading to the starter either - just unplug the negative one first so you don't zap yourself, because that hurts. Battery cables can be the cause of many problems you wouldn't suspect.
'98 S70 T5
confused_al
- Year and Model: 1996 TLA wagon
deleted
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
- E Showell
Problem was ultimately traced to a bad negative battery cable. The ground connection to the block near the front frame cross-member was severed. I tried the budget repair of hammering on a new cable end and that just prolonged the misery. After replacing the negative battery cable with new, the problem seems to have disappeared. Additionally, noticeable driveability problems in the form of random misfires and the accompanying check engine light seem to have abated as well.
'95 855 auto (sold)
'95 855 auto (sold)
