T6 Lifters?
00_Coupe
Year and Model: 2000 S80 1998 S90
T6 Lifters?
Post by 00_Coupe »
Hello,
Could you guys and gals explain how the lifters work on the S80? I was under the understanding that they are automatically adjusted hydraulic lifters. However when I took them off they look like solid lifters.. For example if you replaced a valve or a lifter are they all the same??
Thanks
dcarlson12
Year and Model: 1997 850 T5
Post by dcarlson12 »
From what I can see on the attached file from VADIS, they are solid and the only way to adjust them is to get tappets of varying heights to match the require clearance. Others can chime in if this is not correct...
valve clearance setting adjusting.pdf
(1014.75 KiB) Downloaded 332 times
