S 80 Sunroof Won't Close
This topic is in the MVS Volvo Repair Database » S80 Sunroof Won't Close
jeffdowns
Year and Model: volvo 2000 s 80
Post by jeffdowns »
I don't know? Where would it be located? This is driving me crazy.
Would you have any idea what that buzzing noise is in the drivers door? Only happens when I am locking/unlocking and even opening the door.
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
This one:
jeffdowns
Post by jeffdowns »
under the hood where the fuses are? The car is new to me.
You are really something else. Thanks so much for your patience
vegasjetskier
No, the one in the picture is in the headliner by the sunroof switch.
jeffdowns
Post by jeffdowns »
I dropped the panel that has the lights in it. It took two 10MM bolts and it dropped out. I disconnected two wiring harnesses so that I could remove the panel further. I looked up inside that now open area but didn't see anything like that. Do I have to take more of the headliner out?
vegasjetskier
vegasjetskier
Nope, the ground connector is under one of those 10mm bolts. Maybe you don't have one on your car. Do you have the autodimming rearview mirror?
jeffdowns
Post by jeffdowns »
I don't have an auto dimming mirror. I did find the ground and it was tight. So, I am going to look for a hex bolt so that I might be able to manually retract it to the closed position.
Thanks so much. You have been so much help.
jfley
Year and Model: 1998 S70 GLT,
Post by jfley »
I just had to replace the ECC motor in my dash and when I fininshed I realized my sunroof was open....when I completed the replacement and connected the battery the sunroof wouldn't close.....thanks to this thread I am saved....open and close the locking mechanism 3 times quickly with the remote resets the upper control module.......this really help and cured my issue......
THANKS SO MUCH!
emk
Year and Model: 1999 S80 T6
Post by emk »
jeffdowns wrote:I don't know? Where would it be located? This is driving me crazy.
@jeffdowns,
That buzzing sound you hear on your drivers door when locking/unlocking/opening is a failing door actuator. My car is doing the exact same thing. My local Volvo dealer quoted me today CAD$350+tax to fix, or $172.41+tax for part only.
1999 Volvo S80 T6 - 210K kms
