Crankcase fumes in car
beazerboy
Year and Model: V70estate 1998
Post by beazerboy »
I get oil vapour fumes in the car after even a short run. Have changed the pollen filter and sealed the cover from the engine bay. Is there a crankcase breather pipe that might be blocked or broken somewhere.?
WeAre06
Year and Model: V70XC 1998
Post by WeAre06 »
Sounds like your PCV(positive crank case vent) is clogged, causing crank case pressure to build. This pressure is now leaking out from the oil fill cap, along with some oil. The oil that leaks out sits under the spark plug cover and cooks when the engine is hot. These burnt oil smells then travel the short distance to your climate control intake vents and then into the cabin.
Search PCV on this site for more answers
check out this too
http://lakesidedp.com/uploadpics/pcv/
Black 1998 V70XC 183k+
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 73 times
Post by FlyingVolvo »
Might not even be PCV at all.
I currently have any issue where oil is leaking from the turbo and some other area, leaking bits on the cat converter which makes for some pretty bad smells in the cabin when I slow down and come to a stop.
Any oil leaks that you're aware of?
2000 V70XC - 340,000 miles
2023 V60 T8 PE
phils94850
Year and Model: 2009 s60 turbo
Post by phils94850 »
having same prob. with wifes 98 s70. PCV is clogged causeing fumes inside the car. Easy way to check is pull the dipstick while the engine is running and if you see smoke puffing out, then your pcv is clogged.
1996 Platinum Edition
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
PCV, leaking seal, or hot oil return line (if your car is a turbo model)
'98 S70 T5
2016 Chevy Cruze Premier
