volvo 850 t5 auto serious hull at hard acceleration
andrew
Year and Model:
Post by andrew »
hi all nice forum with plenty of interesting info. i have the 1995 850 t5 saloon in south africa. my problem is that when im driving and press the fuel pedal to go she will reach approximately 4000 rpm and then just as if she has died give this power dump and then almost immediately pick up were she left off also does the same if you go long road and try to press her past 140km/h tried volvo agents they are confused and not sure what could be rong.
White850Turbo
Year and Model:
Post by White850Turbo »
That is a tough one, but we just had a guy with the exact same issue over on VS. http://volvospeed.com/vs_forum/index.ph ... 22434&st=0 <-- There's the link to the thread. Replacing the fuel pump solved his issue.
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
