Check your cam timing
tjts1
Year and Model: 96 855 NA 5 speed
Been thanked: 4 times
Post by tjts1 »
The cam position doesn't matter at this point. It is 3 degrees retarded no matter how you rotate in that picture. Don't mess with cam timing until after you have your engine rebuilt, timing belt installed an running.
Ambitious but rubbish
9394volvo850s
Year and Model: 93 850 5spd 94 850T5
Post by 9394volvo850s »
I agree get it together and running. its easy to do with the motor in the car.
93 850 5spd 320k (the daily)
94 850 T5 190K (race car)
95 T-5R wagon yellow (summer wag)
90 745 5spd 295k (winter wag)
67 122 2 door 4spd 69k :))
djm850
Year and Model: '97 850
Post by djm850 »
OK. I'll just assemble the cams timed for TDC, then center the sprockets on the cams, then install the belt and see where the timing marks end up after turning the cranks a few times.
djm850
Post by djm850 »
OK, I've got everything back together and I'm waiting on a new tensioner. Here's the position of the cams. Note the exhaust cam being advanced. I left it that way since when I was threading the belt on with everything tight from the crank up to the intake sproket, the closest tooth on the exhaust that fit was actually by advancing the cam forward a tad. Is this OK?
advanced timing.JPG (211.02 KiB) Viewed 3637 times
exh cam.JPG (226.61 KiB) Viewed 3637 times
9394volvo850s
its like that because the Factory set them all retarded on the exhaust cam. so now you have it at the real TDC. all 3 of mine run great like this. better then factory.
djm850
Post by djm850 »
Awesome! Thanks. That's what I figured. I started out this way by re-centering the sprocket to the cam instead of where it was from the factory. When I went to place the belt on the exhaust sprocket from the intake, I turned the exhaust clockwise to the closet tooth to get good tension on the belt and this is where it ended up. Next up, provided it fires and I get it home tonight, is to re-do the negative battery cable. The connection with about 10 small black wires that goes to the main cable broke. It's fixed temporarily, but after reading some other posts, I'd like to fix it right.
Been thanked: 504 times
Post by cn90 »
Fantastic thread.
I really needed this info!
PEWPEW
Year and Model: 855 GLT 1994
Post by PEWPEW »
Just adjusted my cam timing. Some idiot when replacing the belt had the exhaust full advance and the intake 5 degrees retarded. Much better on the test drive. I had just done some freeway driving before doing this and I was struggling for power, bad fuel economy.
1994 850 GLT Estate
1996 850R Estate
1999 V70 T5 Estate
2000 Lexus IS200 1JZ-GTE
1989 Range Rover Vogue
1994 Honda CBR250RR
2 cats.
