2005 S60..Where is turn signal flasher
bkfm72
Year and Model: 2005 S60
Post by bkfm72 »
Sounds like its behind gauge cluster. How do you get to it?
otis44
Year and Model: 2006 S60 T5
Post by otis44 »
I don't think your car has a flasher relay similar to what you may have seen on another or older car. I think the flashing is computer controlled, but it's very possible I'm wrong about this.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
bkfm72, welcome to Matthew's Volvo Site.
The turn signal flasher is built into the hazard warning light switch.
If you have a loudspeaker mounted in the centre of the dashboard you need to remove this to access the back of the switch to push it out. Turn the speaker grille a 1/4 turn and gently pull it up. Remove 4 screws, the speaker and its connector. Press out the hazard light switch and disconnect it.
What problem do you have with the flasher unit? There are numerous cases recorded of a good hard tap putting things right.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
bkfm72
Post by bkfm72 »
It quits intermittently. Just started doing that recently. It starts working all by itself. I didnt think they were combined but this will help with diagnosis. Emergency flashers worked when turn signals didnt.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Take the butt end of a screwdriver and give the switch a good hard whack and see if it stays working for a while. If not, you'll need to buy a new switch. It was about $72 from the dealer for my S70 - I'm not sure how much it'd run on an S60.
'98 S70 T5
2016 Chevy Cruze Premier
