How do you remove exterior door trim?
rsmigel
- Year and Model: 1994 850 Turbo
- Been thanked: 2 times
What is the best method of removing the exterior door trim (door ding guard) on a 1994 850T wagon w/o damaging the door? I have new trim and obviously don't want to damage the sheet metal prying around.
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Door trims: There is a screw in the rear inside edge of the door which holds the trim in place. Remove the screw and push the trim forward about 1cm. The easiest way to move the trim forward is to tap it with a block of wood.
The later trim is held in place by double sided tape.
Front wing (fender) trims: Carefully pry off with a steel putty knife with a piece of wood against the paintwork to protect it.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
tailor
- Year and Model: 2004 XC90 2.5T AWD
I was going to say let one of your kids drive the car, it worked for me!
Below there are six pictures depicting my Volvo and the result of the car being a loaner
There is no double sided tape only clips. My model at least!!!
The front quarter panel has clips that just push in, these broke off and pushed all the other trim back. I have tried to connect the trim back on the car and have found that there are a few things that need to be considered.
1) The clips need to be on the trim and not the car.
2) Open the doors. All the clips except the last will be slid into place from the front of the door to the back. Before pushing in the last clip check the alignment of the trim in relation to the door opening and closing and the other trim. If it is out you will have concertina effect and the trim will pop off. Once in place the last clip, closest to the back of each door will be the last to be inserted or pushed into place. The doors need to be open.... once the trim is on you may have to
3) Get new clips all round
4) Work in a heated garage or wait until the weather gets kinder so the parts are not to rigid in cold weather.
To remove:
So in summation, either let your kid drive the car or gently pry off the rear section of the trim being careful not to bend the trim, and then slide the trim forward and it should come right out. Be prepared to break a few clips, you may also find that the clips come away from the trim and stay on the car.
+ 1 for putty knife and wood block.
To remove:
1994 850 Auto Turbo wagon 306000km (Sold)
2004 XC90 AWD 188000km
"Life is like a reel to reel tape recorder,
the closer you get to the end,
the faster it spins."
Abe Gottschalk
Abe Gottschalk
- Has thanked: 292 times
- Been thanked: 765 times
Just want to post this because someone bumped up this thread today:
Don't do any prying on the door trim like tailor advises. The proper way is to remove the screw then just slide it forward, it will fall right out and nothing will get damaged.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Ben850
- Been thanked: 7 times
Yes, it seems he may not have been aware of the screws in the doors. I found out at a pick and pull, which is the only place to experiment before doing bad things to your own vehicle.erikv11 wrote:Just want to post this because someone bumped up this thread today:
I changed the thin '93 alter 1 door moldings out for wider '96 pieces after changing to the alter 2 bumper.
- wider door moldings with new bumper
- sunset grille.jpg (67.57 KiB) Viewed 9243 times
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Door trim removal video:
- 797 Views
Last post by Volvo S80
- 637 Views
Last post by bmdubya1198
