96 85 160k
Recently, and about 1 out of 4 starts, when I crank the ignition I get a "flat" cranking sound. If I turn the ignition back, the engine cranks right over. I have no CEL light and all maintenance is up to date including a battery only one year old. I seem to have plenty of cranking amps and alt holds charge. Plugs have about 25k but wires are orignal. Could it be starter? How would I diagnose?
Thanks in advance-
Please diagnose start issue
White850Turbo
- Year and Model:
You have the original wires that came with the car?!?! If so, that could very well be the problem. Also, turbo'd cars go through spark plugs rather quickly, so 25k is kinda high mileage for plugs.
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
By "flat cranking" I mean there is a starting sound but it is not the usual he he he he...start it's more of a falt whining heeeeeeee sound then I take the key back to the O position and forward again and it starts right up. I know its hard to diagnose by sound but the best i can do to describe.
The solenoid is part of the bendix system which moves the small gear of the starting motor to engage with the flywheel gear . Most likely the mechanism needs lubrication but possible replacement.This will be a lot cheaper than a new starter
VolvoFreak
- Year and Model:
I agree - starter solenoid is bad
1993 850glt
219,000+ miles and counting
Guest
where is selonoid on 850? have a pic perhaps? how easy to clean or replace?
thanks again you guys are rad!
Quondo
You may actually want to look at the ignition coil first, rather than the starter. I was having the same problem on my '93 850 GLT and since replacing the ignition coil, it's been starting like a dream!! Good Luck!
