Passenger side was cake, driver side had some challenges, so here goes...
Here's a step by step of the passenger seat (manual type):
remove seat bolts
Detach seatbelt and remove the bracket
unplug harness of seat heater and remove seat from car
Prep V70 seat
Remove seatbelt bracket from V70 seat
Bolt in 855 seatbelt bracket into V70 seat
Remove V70 seatbelt latch
Remove 855 seatbelt latch and install into V70 seat
Install prepped V70 seat into 855 and bolt everything in and replace the side cover before replacing height adjustment handles.
One thing to note is the V70's height adjustment handles have a plastic tab on the inside that needs to be wedged slightly to remove the handle, I broke the first one trying to force it out with a screwdriver
