So my 94 850 has been stalling everytime I try to start it after a trip. In other words, I drive to a store, when I come out, it won't start for at least five minutes, then starts right up. If it sits long enough, it will start so no quick stops for me.
I live in AZ and it's over 100 degrees now. Today, when I came out to my car after work it would not start. It basically will not catch, just chug. So I waited 2.5 hours for the sun to go down some and it to cool a little (yeah right!). Well it started right up. SOMEONE PLEASE HELP!!!! The body and interior of this car is pristine! I do not want to get rid of it. I have read in numberous posts that the fuel pump and/or relay are the culprits to many stalls. Could this be heightened by temperature?
850 Stalling Issues - More so in hot weather
Guest
Maybe it's vapor lock. Does it do it only on short trips or after long trips as well? I had a Ford that did exactly the same thing once, and it turned out to be a tiny vacuum leak. Just an idea. Probably the Volvo has something weirder going on!
Guest2
White850Turbo
- Year and Model:
Check for:
1. Codes
2. Spark
3. Fuel
1. Codes
2. Spark
3. Fuel
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
Guest
No it really doesn't matter. When it was cooler out, I could drive to the corner store (1 mile) in the morning, run in for a minute and it would start again. Anything trip longer than that and no start right away. Whatever it is, is definitely affected by temperature. But remember that I live in AZ and it's 110 right now so most cars would be.Anonymous wrote:Maybe it's vapor lock. Does it do it only on short trips or after long trips as well? I had a Ford that did exactly the same thing once, and it turned out to be a tiny vacuum leak. Just an idea. Probably the Volvo has something weirder going on!
There is a small offwhite hose with a black elbow fitting that has broken off. Maybe a vacuum line? I'm changing the fuel pump relay anyway as it resides in the engine compartment which could explain why the car needs to sit a while before restarting. It has stalled on teh freeway as of late and once or twice at stop lights.
Guest
That broken off hose/elbow sounds like something to fix. Another possible cause:
https://www.matthewsvolvosite.com/chat/p ... php?t=2680
Especially if it stalls out under ALL conditions (idling and while moving) and takes a while to restart the engine after the engine is warm.
- 24 Replies
- 1130 Views
Last post by TisMe
- 48 Replies
- 11137 Views
Last post by bmdubya1198
- 21 Replies
- 6017 Views
Last post by Oitsujosh
- 716 Views
Last post by MoVolvos
- 1155 Views
