My 94 850 will occasionally not start. Good solid cranking but no start. If I let it sit 2-3 hours it will start with no problem. The diagnostics show an error code for missing and intermittent camshaft position sensor signal
(3-1-4 and 3-2-4). Does anyone knows if that sensor could be the reason of my problem.
New parts: spark plugs, battery, wiring and cap. (within 1 or 2 years)
It would make sense to me that it is having the problem. I have seen over the years that electronic sensors or controllers will fail more often when warm and will
95' Volvo 850 GLT, Lots 'o' miles, 118k, Broke in just right.
90' Ford Ranger 4x4, Even more miles, 145k, Seat is broke in just right.
02' Ford F-250 Super Duty 4x4, 85k, Working on the first 100k
Thank you very much for your help Da'Moose, I will try your recommandation. Does anyone have information on how to change that sensor? Other than Volvo, is there any other places to buy that camshaft position sensor.
I am having a similar issue. After the car sits over night it appears as if I get no spark at the coil. If I leave the key in the on position for a minute or so it will eventually give spark and start. Been a little bit of a trick to diagnose as I just decide I have no spark then I get spark and the car starts.
I pulled the codes and have both 3-1-4 and 3-2-4. As I understand it one code is sensor missing and one is sensor missing intermittently. Think this is my problem? Also had a code stating RPM sensor intermittently. Looks like the sensor is a bit pricey to guess on.
Thanks I was all set to do some testing this AM figuring the car had starting difficulty the last 3 mornings in a row. Headed out at 6:00 AM with timing light in one hand and fuel preasure gauge in the other. Turn the key and car starts right up. Go figure. Maybe I just need to bring those with me every morning!
I will keep an eye on the codes and see if they trip again. I am leaning towards the CPS as the problem but want to make sure I completely rule out fuel side. I will try to keep posting as I resolve the issue.
