Hi guys,
I am trying to service my EGR and was wondering
1) What is the torque spec to torque the 4 bolts attaching the throttle body pulley?
2) Does 97 850 turbos have EGR? I checked mine and it looked nothing like MadeInJapan's (https://www.matthewsvolvosite.com/forums ... =1&t=19549) There is no valve beneath the body???
EGR Cleaning
Volvo 850 EGR Cleaning Tutorial
- pkc303
- Year and Model: 1995 T-5R Yellow
- Been thanked: 3 times
Our 1995 has the EGR valve, but the 1997 does not. So, I guess you would be able to see it when you pulled the hose off the throttle body, or look under the intake manifold on the driver's side (U.S.)
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
patrioty3k
- Year and Model: 1995 850 Turbo Wagon
1995 850 Turbo S/Wagon,Alpine head w/Sirius Sat. Radio--"OCTANE" power!
200K $400 Sleeper...nuff said!
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
If it has this (the EGR), which is circled in the picture, then it does- if not, then it doesn't.
tailor
- Year and Model: 2004 XC90 2.5T AWD
- Been thanked: 2 times
MY 1994 Wagon does have one.94turbomom wrote:Does my 1994 850 turbo wagon have an egr? I hope thats not a stupid question but Im about to get the pcv system cleaned and it sounds like maybe it would be helpful to know.
Thanks everyone
...Tiana
If you have an EGR, as depicted in the pic submitted by MIJ, I would be interested to know if you can attach the EGR to the manifold first and then attach the manifold to the block.You say the PCV has to be done any way, if you can get the manifold off with the EGR on, the opposite should apply. If it works, you could then torgue the bolts correctly.....gut en tight = snap, in my case.
The great big(brass) nut on the back of the EGR would have to be removed first and then the manifold bolts, the theory is to pivot the bottom of the manifold upwards and then remove the entire manifold and EGR together.
The bolts holding the EGR are just awful to get to and then you also have the problem of overenthusiastic tightening to contend with ! I know, I snapped one right off, if there was jail time for each foul word I used, I would still be in lock up
Tell us how you go!
1994 850 Auto Turbo wagon 306000km (Sold)
2004 XC90 AWD 188000km
"Life is like a reel to reel tape recorder,
the closer you get to the end,
the faster it spins."
Abe Gottschalk
Abe Gottschalk
- Year and Model: Many Volvos
- Been thanked: 76 times
Not a stupid question at all but it all depends on your emissions code. The short answer is that some do and some don't.Does my 1994 850 turbo wagon have an egr? I hope thats not a stupid question but Im about to get the pcv system cleaned and it sounds like maybe it would be helpful to know.
A visual inspection of your car should provide the answer. Cars with EGR have a stainless steel tube (about 1/2" diameter) running from the (US) driver's side of the exhaust manifold to the EGR valve which is bolted to the intake manifold just behind the throttle body. There is also a vacuum line that runs to the EGR valve from the EGR valve controller which is mounted on the fan shroud.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
If you're removing them (the most effective way to do it), you will need both gaskets.
Advance Auto parts can order them for you, and they're about $1-2 each.
'98 S70 T5
2016 Chevy Cruze Premier
- 1099 Views
Last post by wanderdüne
- 684 Views
Last post by Ozark Lee
- 789 Views
Last post by erikv11
- 740 Views
Last post by southofmotown
- 13 Replies
- 7088 Views
