Replace Piston Ring? Misfire #3 P0303
commlend
Year and Model: 99 70xc
Post by commlend »
Hello Everyone,
I have a misfire on #3- P0303. I pulled plug and it was covered in oil- like it was dipped in oil covered. I cleaned it up and cleaned coil, seemed to idle fine for about 10 seconds, then started to misfire again once the oil pumped around and saturated it. The cel flashes when I get up to about 30mph.
I am going to do a compression test to confirm but is it most likley a piston ring?
If it is a ring can I push the piston up from the bottom of the car ( with the head off) without removing the engine?
How long can I drive it with a dead cylinder? Do I now have as much power as a 4 cylinder honda civic :lol:
If I decide to drive it into the ground and part out the rest of the vehicle how long do you think before it doesn't even drive? I would just want enough time to find another vehicle- few weeks or month max so I can be picky and find something decent.
Any advice on replacing the piston rings. Even a shade tree method to buy some time would be worth a few laughs also. :mrgreen: Thanks
Ben
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
I think I'd move on to a compression or even a leakdown test before doing anything drastic.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
I think very rarely does a piston ring just blow out entirely. My parents have got a 74 BMW and a 20-year old lawnmower with leaky rings, and while they both smoke like hell when they start, they both run just fine.
Clearances are pretty close in the Volvo engines, though, and they usually don't have these problems.
Do a compression test dry, and then add a squirt of oil to that cylinder and re-do the test. If your pressure jumps dramatically, you DO have a bad ring.
I'd say more likely it's a valve seal gone bad, but the compression test will tell you more.
'98 S70 T5
2016 Chevy Cruze Premier
commlend
Post by commlend »
Thanks for the tips jablackburn,
Any takers on replacing the ring by pushing the piston up from the bottom of the block?
It seems like it should work...
commlend
Post by commlend »
I appreciate the help guys...
It ended up just being a coil pack. Thanks again.
Ben
jblackburn
Always good when it's something easy :mrgreen:
'98 S70 T5
