Seafoam works.
Volvo Seafoam Works
luketrash
- Year and Model:
- Been thanked: 2 times
The plug of carbon/nasty oil that was in my oil seperator was not all that solid, so I could defintely see how seafoam would eat into it. However, I worry that seafoam could also eat the rubber/plastic parts of the PCV system when used full strength in there.
'94 Gunmetal Gray 855 2.4L 100% stock. This is Volvo #7.
JRL
- Year and Model: Several
- Been thanked: 16 times
The trick is to run it.
Besides the usual Seafoam process, after the initial 1/2 to 1 hour of "blowing it out", change the oil and drive it for 50-75 miles.
Do it with 1/4 tank (or less) of gas, THEN fill it up to dilute it even more before the drive.
I haven't heard of any damage to any engine's internal parts when done properly.
This stuff and others like it have been around for 60-70 years or more, they wouldn't still be on the market if they destroyed internal parts
- Has thanked: 2861 times
- Been thanked: 1332 times
Here's a quick How to Use Seafoam video from the manufacturer.
I am most definitely looking forward to running a treatment or two of Seafoam in my Torino later this month. I expect to make a huge mess of smoke so I'm going to do it on a county road outside of town. Then when I'm done, I plan to rebuild the carburetor and change the plugs, wires, cap, and rotor (have all but the wires to do all this so far, and I'm one RockAuto order away from that). The car is so deserving of SOMETHING after it has been so abused and neglected by the previous owner.
I suppose Seafoam would be very useful in a 229K mile '93 850? That's the Volvo I'm looking at now, $800, in Austin, and I think it would be a better commuter car than the Trans Sport P.O.S. I'm using now.
Alan Moore
Hill County, TX
2000 Durango 4x2, pewter/black, 318/42RE, 190K
1990 Trans Sport, red/gray, 3.1L/TH125, 245K+
1976 Gran Torino, white/blue, 351M/FMX, 88K
1976 Gran Torino wagon, copper/brown, 351M/FMX, 112K
Hill County, TX
- phils94850
- Year and Model: 2009 s60 turbo
Just did a seafoam treatment today. As recommeded on the other post i removed the brake booster hose and used a bendable straw so you dont have to worry about over doing it. worked like a charm.
BE CAREFUL !! about using the vacuum tree. I cant say for certain this caused the problem but there was a post on here or VS about someone adding the seafoam at the vac tree and it all went into one cyl and hydrolocked his engine and caused serious damage.
I would suggest using the brake booster hose if at all possible..
1996 Platinum Edition
idrivevolvo
- Year and Model: 94 850n/a 5sp
gonna give this seafoam a try this weekend my 94 850 n/a 5sp with 205k miles n counting just doesnt have the pep it did 50k miles ago gonna do the 1/3 can - crankcase, uel tank and vac line. ill record some numbers before and after to see what the deal is
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Gonna put mine in the intake this weekend - it's already in the crankcase & fuel tank as of yesterday.
'98 S70 T5
2016 Chevy Cruze Premier
I seafoamed my 850 last year, it was just under 300miles at the time. I remember reading that it was going to smoke alot when put through the intake. But when I actually did it I was amazed at the smoke... dark blue/black, I had the garage door open and such but had to jump into the cloud of smoke so I could get in the car and back out into the yard.
Took off up the road and continued to smoke for about 100yards. Did the same treatment on my buddy's crown vic with 200miles on it, and it only smoked about 10% of what mine did.
I guess it depnds how dirty your intake is. I didn't notice any improvements with seafoam, but knowing things are cleaner is good.
Curtis
Curtis
2003 v70 2.5tawd black/black 120miles
2007 nissan altima 2.5 cvt 107miles
2001 xc70 211 miles " collision"/ parts car
1994 850 turbo 315miles 5 speed "stoped fixing it"
whoa
- Year and Model: 850 Turbo Wagon 1996
Ha! Yeah, I've done it in the middle of San Francisco and felt pretty sheepish at how much smoke it put out. Next time, I'll pick an especially foggy day!
1996 850 Turbo Wagon
- 603 Views
Last post by Ozark Lee
- 11 Replies
- 2837 Views
Last post by MarcM
- 2124 Views
Last post by mecheng
- 1020 Views
- 39 Replies
- 6122 Views
Last post by DanelleNavarro
