940 Doesn't Start After Rainstorms
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
cfhosford
Year and Model:
Post by cfhosford »
Hello: I have a 1992 940 GL that often refuses to start after a rainstorm, and once after I went through a car wash. Once it even quit while I was driving in the rain (I went for a bite, and waiting for the rain to quit -- it started again.) There's just no spark during these periods. My mechanic thinks it could be the rubber gasket around the hood, or else a leaking distributor that's allowing water to get in. Does anyone have any idea what could be causing this? Much thanks. - Chris
Chris Hosford
[email protected]
yeagermeister
Year and Model:
Post by yeagermeister »
i would check the distributor cap for cracks first, and make sure it seals up around the bottom- moisture inside will certainly cause similar problems.
another possibility could be the electrical connections on the fuel pump as well, if they are exposed (i'm not sure about the configuration of the fuel system on the 940, but my Nissan Xterra had a similar issue with the Fuel Sending Unit- which was later recalled- which is in the gas tank, but the electrical connection was on the outside of the gas tank.) this corroded, and i had the exact same problems as you.
(the other) sean
'94 855 5-speed
'02 lifted Nissan XTERRA
petershen1984
Year and Model:
Post by petershen1984 »
Your mechanic is correct to suspect water leaking through the seals around (perimeter of) the hood, as the distributor could get wet even with a good cap. In my case, the car was already running and started to idle weird and slow to a stall. I still haven't fixed the seals yet.
Peter Shen
1992 Volvo 960 (Silver)
