Transmission Flush not recommended for 850's
This topic is in the MVS Volvo Repair Database » How to Not Break Your Transmission
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Re: Transmission Flush not recommended for 850's
Post by jblackburn »
I think once you do a couple drain and fills you can graduate to a full out flush. At that point, you don't really even need to drain the pan again, just pull off the radiator hose and flush 12 qts through it. You'll be amazed at how long it pumps out dirty fluid, even after 2 years mine was pretty dirty :mrgreen:
If you have a turbo, or do a lot of hill-climbing or demanding driving, I highly reccomend the Mobil-1 fluid. It smells AWFUL if you spill it :oops: but it works great.
'98 S70 T5
2016 Chevy Cruze Premier
volvomileage
Year and Model:
Post by volvomileage »
sorry ...i ment drain and fill for mine ... :o
volvo 850 95 sedan non/turbo 185 k
IVIUSTANG
Year and Model: 2006 XC70
Been thanked: 4 times
Post by IVIUSTANG »
Craigd2599 wrote:Not an old wives tale. Using synthetic in a high mileage trans that hasn't been serviced will usually deteriorate the seals and clutches
I can't speak for the clutches deteriorating; but modern synthetics will NOT harm seals. This used to be a problem when synthetic was an innovation, but they soon realized that synthetic requires countermeasures to not shrink seals; nearly all of the manufacturers have taken the proper chemical steps.
- Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires :D
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
shiloh51933
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
I got a 96 GLt wit 90 thou on it and I'm doin' drain n' fill with one bottle of Lucas Tranny Treatment and synthetic
tranny fluid since that's what she's always had. I would never flush a tranny unless I definately know her history cause
who knows what you can disturb internally
XxJenoxX wrote:Engines and transmissions get gunky buildup in them which can be loosened by flushes. This may sound like a good thing, but it's an incredibly bad thing when some of those gunky deposits don't flush out, and they basically move around and clog things up even worse than they were just being left alone in there.
I
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
marginal
Year and Model: V70 D5 2003
Post by marginal »
I did the drain & fill using (as suggested by a mechanic from Volvo) CASTROL ATF+4.
Now it shifts rough but not much.
Next, I am going to do another drain & fill, but before that, I'll add the Sea Foam Trans - Tune ...
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
- Jesse
+Infinity
mdempst_79
Year and Model: 2006,2007 XC90
Post by mdempst_79 »
My 97 850 had over 400,000km on the tranny when I did a drain & refill a few times. The fluid was not burnt at all (non-turbo) but you could tell there was quite a bit of metallic content in the fluid. When I drained it and looked at the pan it had a metallic look to the fluid, and it looked like candy-apple paint. Trans is still working fine now 20,000km later. I honestly think this trans will outlast the engine. My V70T-5 tranny went out @ 270,000km (diff broke).
Drain & refill every oil change and your car will last a long time.
Mark
2007 XC90 V8 Sport 265,000km
1994 850 Turbo Auto 365,000km (R.I.P - 2005-2017)
2006 Ford F350 Super Duty 4x4 Diesel
1999 Landrover Discovery II 259,000km
1992 Range Rover Classic 3.9 250,000km (In restoration)
FastLane
Year and Model: S40 MY00
Post by FastLane »
Well, there are differences. I think Jesse and Mark are right on. OK, not doing the transmission every oil change, but certainly staying on top of it. Transmissions are much better 'sealed' than an engine, and don't have openings and blow by to contaminate them, so they need a lot less service over their lives.
Draining and filling a transmission isn't bad. If your car holds 8 quarts, and you can drain 4, such as my S40, you can get 50% of the fluid out in one drain and fill. I would not think at any time fresh fluid would cause a transmission to fail. Kinda defeats the purpose of changing the oil in the first place... I would be more leary of the process than the fluid.
On my MY00 S40 last fall, with 90k, I drained it, topped it off, drove it until the next weekend and did it again. That got the fluid pretty well cleaned up after a few weekends. And, it had not been done by the last owner, per the silly "sealed for life" crap they were doing ten years ago. In theory, fluid goes from 50% clean to 75%, to 87.5%, 93.8% etc., right now I am at like 93% fresh ATF. I will also do that process once a year, which should more than stay ahead of the oil's deteriation and breaking down /aging processes. Of course it varies on what comes out, but I have a basic script that will calculate it.
I am not sure of the issue about synthetic. My S40 calls for Dexron II/III, its from just before the 3309 cars came out. 30 years ago, there were problems with seals, etc. not reacting well to the synthetics. But back then, the seals relied on components in oils to keep them "wet" and swollen/pliable. In the last 15-20 years, the explosion of synthetics and people understanding their benefits, as well as factory specs, have forced manufacturers to make seals and gaskets capable of handling all types of oils. Even though it specs a synthetic, a lot of people (Dealers!!) will cut corners and still use dino oil.
I am not exactly sure about the varnish issues, whereas cleaning the inside of the trans causes any varnish to break down leading to leaks, catastrophic failures, etc. Were that the case, I would be nervous with Type-F, as it is has a lot more detergent, that might cause problems. I am wondering if some of the afore mentioned issues were from the flushing itself.
I can see issues with power flushing, such as forcing fluid through valves the wrong way, pushing 'dirty' fluid back into bearings, or blowing out filters, seals, etc. But I imagine a lot of the yocals doing flushes are not aware of the consequences of ramming fluids backwards through the valvebodies and bearings, filters, etc. I have taken apart transmissions with 150k plus on them and they looked factory new in terms of the fluid deposits. They had wear, but weren't varnished at all.
Clean fluid would have better additive properties (seal conditioners?), less microscopic crap in it, things like that, but I don't get how it ruins a gear box.
Anyhow, I am enjoying lurking here and decided to post. Looking forward to hearing back.
Mark
polskamafia mjl
Welcome to MVS and thanks for posting! I've never taken a tranny apart so I can't give any opinion on that but I do agree with your post.
FastLane
Post by FastLane »
Thanks. Well, I am not sure about everything going on here, but it made sense to me.
