shift lock problems '96 850 turbo wagon Topic is solved
850 fam
Post by 850 fam »
Every so often (once or twice a week), I'm unable to shift out of park without engaging the shiftlock override button adjacent to the shift lever. Is this a common problem? What is the remedy and is it a "do it yourself" issue? Also, just curious, if anyone knows why when I engage the override feature, the instrument panel and turn signals do not power up?
Jot
Year and Model: C30 2010
Post by Jot »
www.volvospeed.com repair/maintenace has step by step with photos
850 fam
Post by 850 fam »
Thanks for the reply. Everything I need, including detailed digital photos, was there under http://www.volvospeed.com/Repair/microswitch.php. The problem seems to be fairly common.
Guest
Post by Guest »
I remember when I had this problem for a couple of weeks years ago and then bam, magically, it just went away... Go figure. '94 850 n/a
