This message came on yesterday , my volvo has 53000 miles. I checked the transmission fluid, the color, smell and levels look great. The car seems to run fine, the transmission seems to be functioning normal.
What would make this message appear?
How can I remove this message from the display? I have already tried a reset by putting the ignition key into position I, push in and hold the odometer reset button (use your left hand), move the ignition key to position II, when the service light begins to blink,let go of the odometer reset button. It didn't work.
Thanks
John
S80 2001 Dash message "Transmission Service Urgent"
jwstephens2002
- Year and Model:
Guest
Did you end up getting it fixed? My '99 S80 wants a "Transmission service Urgent" as well. My Mechanic said its fine.
mjlanser
The message eventually disapeared. However I did have to take the car later on get the fuel throttle replaced. when they ran the diagnostic there was a message that said the transmission was going out. I am going to drive it as is and if the transmission goes out I will deal with it then.
new99S80owner
guestfromauckland
The same message started to appear on my s80 2.0T 1999 a few weeks ago(it is an AW 4 speed auto transmission). Howerver, local volvo dealer told me that the ABS control unit needs to be repaired to fix this problem. Since I don't feel anything unusual, I will not do any repairing work on the transmission itself. I will deal with it when it comes.
- 1393 Views
Last post by 20yearsandcounting
- 1992 Views
Last post by ThommyKent
