EGR Cleaning
This topic is in the MVS Volvo Repair Database » Volvo 850 EGR Cleaning Tutorial
VolT5
Year and Model: 850 T-5 1997
Post by VolT5 »
Hi guys,
I am trying to service my EGR and was wondering
1) What is the torque spec to torque the 4 bolts attaching the throttle body pulley?
2) Does 97 850 turbos have EGR? I checked mine and it looked nothing like MadeInJapan's (https://www.matthewsvolvosite.com/forums ... =1&t=19549) There is no valve beneath the body???
pkc303
Year and Model: 1995 T-5R Yellow
Been thanked: 3 times
Post by pkc303 »
Our 1995 has the EGR valve, but the 1997 does not. So, I guess you would be able to see it when you pulled the hose off the throttle body, or look under the intake manifold on the driver's side (U.S.)
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
patrioty3k
Year and Model: 1995 850 Turbo Wagon
Post by patrioty3k »
:( How does one get that wire off the egr?Doing complete PCV change,as noted in other post.Can I just cut the wires and re-splice?Thanks.......
1995 850 Turbo S/Wagon,Alpine head w/Sirius Sat. Radio--"OCTANE" power!
200K $400 Sleeper...nuff said!
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
If it has this (the EGR), which is circled in the picture, then it does- if not, then it doesn't.
EGR pic.jpg (28.37 KiB) Viewed 3860 times
tailor
Year and Model: 2004 XC90 2.5T AWD
Post by tailor »
94turbomom wrote:Does my 1994 850 turbo wagon have an egr? I hope thats not a stupid question but Im about to get the pcv system cleaned and it sounds like maybe it would be helpful to know.
Thanks everyone
...Tiana
MY 1994 Wagon does have one.
If you have an EGR, as depicted in the pic submitted by MIJ, I would be interested to know if you can attach the EGR to the manifold first and then attach the manifold to the block.You say the PCV has to be done any way, if you can get the manifold off with the EGR on, the opposite should apply. If it works, you could then torgue the bolts correctly.....gut en tight = snap, in my case.
The great big(brass) nut on the back of the EGR would have to be removed first and then the manifold bolts, the theory is to pivot the bottom of the manifold upwards and then remove the entire manifold and EGR together.
The bolts holding the EGR are just awful to get to and then you also have the problem of overenthusiastic tightening to contend with ! I know, I snapped one right off, if there was jail time for each foul word I used, I would still be in lock up :shock:
Tell us how you go!
1994 850 Auto Turbo wagon 306000km (Sold)
2004 XC90 AWD 188000km
"Life is like a reel to reel tape recorder,
the closer you get to the end,
the faster it spins."
Abe Gottschalk
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Not a stupid question at all but it all depends on your emissions code. The short answer is that some do and some don't.
A visual inspection of your car should provide the answer. Cars with EGR have a stainless steel tube (about 1/2" diameter) running from the (US) driver's side of the exhaust manifold to the EGR valve which is bolted to the intake manifold just behind the throttle body. There is also a vacuum line that runs to the EGR valve from the EGR valve controller which is mounted on the fan shroud.
nadz
Year and Model: 850, 1995 N/A
Post by nadz »
Do I need to buy any gaskets or other things if I want to clean the throttle body and EGR?
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
If you're removing them (the most effective way to do it), you will need both gaskets.
Advance Auto parts can order them for you, and they're about $1-2 each.
'98 S70 T5
2016 Chevy Cruze Premier
