cannot shift out of park on hot days without shift override Topic is solved
On days when the car sits in the sun (usually the outside temp is 70F+) the car will not shift out of park without 'shiftlock override' Then while driving the turn signals, and odometer, speedometer and who knows what else, don't work. 1996 850R Wagon 203,000mi.
dpauto.com
- Year and Model:
Sounds like you need a new ignition contact switch. Its a common problem.
Dave
Dave
ASE - VOLVO Master Technician
wow, what makes you drive so much? live in alaska or something1996 850R Wagon 203,000mi.
most cars can run for a long time, given that you take good care of it
shawn
Hey, I Just tuned it. How much did it cost to replace the igintion switch to fix the shift lock problem?
Thanks,
Shawn
Thanks,
Shawn
daria
I had my car at the dealer a couple of weeks ago for "Can't shift out of park problem". They told me I needed to replace the micro gear switch. Can you tell me where this is located and if I can replace it my self? (San Diego Volvo didn't have the part)
I'd appreciate any help/advice.
Thanks, Daria
Thanks, Daria
