What did I screw up on my 740T?
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
dtomm4
Post by dtomm4 »
Just got my first Volvo home today, an 89 740 turbo wagon with 178K. It had sat for a year but I got it fired up easily and it ran fine. Has been starting and running well until today. After I got it home I pressure washed a years worth of dirt, leaves and grime and wanted to clean up the engine compartment too. I was trying to be careful and avoid the electrical stuff, so of course now the car runs like crap. It will crank fine and barely catch, chugging, sputtering and surging at idle. If you gas it it'll stall or stumble, slowly building up revs until it smooths out at about 3K. Seems to run ok at constant high revs but terrible at low speeds.
I tried drying off all the electrical stuff I could think of that may have been exposed to water. Nothing. I did notice that the boost needle stayed in the white at all times. At constant hi revs its well below the yellow mark and when I try pounching it and the revs start building up the needle goes near the top of the white then back down never getting into the yellow. I thought previously the needle was running in the yellow under boost but I'm not sure. Could it be related to the turbo? Anywhere you can suggest I look? This is my first Turbo and Volvo so I could use some guidance. Any input would be appreciated. Thanks
Dave
Volvord
Year and Model:
Post by Volvord »
Sounds like you probably got water inside the distributor cap.
Remove the cap and leave it off to dry, if time is limited the best method of drying a distributor is pouring some rubbing alcohol into the cap and then dump it our and let the residue evaporate. Alcohol absorbs water and will get rid of the water.
http://www.Volvord.com
1998 C70
1989 744TI with a 400HP Ford 302 / 5 speed
