Hi there -
The auto gearbox on my 1994 Volvo 850 20v GLT gets lazy when it's been standing for a few days; it doesn't want to shift from first gear, though when I temporarily move the gear lever to the "3" position the box shifts up as normal, and when I then change back to the normal Drive position, the problem stays gone.
I have checked the oil level carefully as per my Haynes service manual instructions. Any ideas? Many thanks!
auto 'box won't shift up when it's not been used
Hardwire Your iPod to Your Volvo
wildatheart
- Year and Model:
1965 Volvo 122S
1970 Mercedes W113 280SL
1971 BMW 2000 Touring
1986 Ford Capri 280 Brooklands
timsterman
- Year and Model:
Does an arrow on your instument panel flash ? Try pulling codes to see if any "hard codes" are stored. Sometimes you can have a solenoid stick iside trans.
wildatheart
- Year and Model:
timsterman wrote:Does an arrow on your instument panel flash ? Try pulling codes to see if any "hard codes" are stored. Sometimes you can have a solenoid stick iside trans.
There is no flashing arrow, there appears to be no fault code (and I changed the fluid, to no avail). Could it be a sticking solenoid even if briefly moving the lever to "3" fixes the problem for the rest of the journey?
I would dearly love to fix this problem.
1965 Volvo 122S
- 512 Views
Last post by carguy124
- 14 Replies
- 4021 Views
Last post by commandoNate
