Mod note
Spec is min 0.3 mm, max 0.5mm
( Many countries don’t use the metric system , so this is 0.012-0.020 thousandths of an inch.
Many = Yemen plus the USA)
Source alldata
My 850 is showing the well know AC clutch gap problem. Measured the gap and it is 0.035+ (0.035 is the largest feeler gauge I have.
Been saving clips and am ready to go.
Is access to the compressor better from under the car after removing the plastic shroud?
-os
Generic P80 AC clutch shim , bread clip, zip tie thread
AC Shim Fix: Are Zip Ties the New Bread Clips?
1996 850 GLT 262k miles (gone
1999 Honda Civic (gone)
1996 850 GLT (gone, no more Volvos
2000 Buick Park Avenue (gone)
2005 Honda Odyssey (gone)
2013 Lexus ES350 (replaced Volvo 850)
2021 Honda Pilot
2021 Honda Pilot
- Year and Model: Many Volvos
- Been thanked: 76 times
It is very easy from the bottom, I don't even want to think about going at it from the top. Two bolts and the air guide will come right off.
JRL
- Year and Model: Several
- Been thanked: 16 times
I do them from the top, it's really not that hard except for one clip.
Use a LONG screwdriver and you should OK
JRL wrote:I do them from the top, it's really not that hard except for one clip.
Why is one clip hard? Doesn't the clutch plate rotate? I can move mine around.
-os
2021 Honda Pilot
2021 Honda Pilot
Ozark Lee wrote:It is very easy from the bottom, I don't even want to think about going at it from the top. Two bolts and the air guide will come right off.
Thanks!
2021 Honda Pilot
2021 Honda Pilot
KRUZNBY wrote:What is the symptom if the gap is too large? The compressor does not engage?
My AC runs great - for about 20 minutes. Then blows normal air. Turn it off, wait a while, turn it on and the cold air is back.
Gotten worse with all the really hot weather.
Measured the gap it is was more than the 0.02" spec.
2021 Honda Pilot
2021 Honda Pilot
On the photo on volvospeed, it shows the clips on top of the rubbeer washers. On mine, I can't get the clips on as the washer doesn't move enough or my clips are to thin.
Is there any reason I can't put the clips below the washers. They're held pretty tight there so I don't think they'd fly off if I spuer glued them there.
-os
2021 Honda Pilot
2021 Honda Pilot
C@lvin
- Year and Model:
- Been thanked: 2 times
I'm not really sure what you mean by "below the washers" but you will need to pry the clutch with a screw driver or something to open up the place where he is showing that the bread clips go. I think if you try to put the clips anywhere else you will have difficulty getting a uniform gap around the circumferance of the clutch. Read the volvospeed post once more and see if it makes more sense. If not, can you post a picture of your clutch or even post his picture and point to the "washers"?
Calvin
98 S70
00 V70
240,245,760,940,850 Turbo
98 S70
00 V70
C@lvin wrote:I'm not really sure what you mean by "below the washers" but you will need to pry the clutch with a screw driver or something to open up the place where he is showing that the bread clips go. I think if you try to put the clips anywhere else you will have difficulty getting a uniform gap around the circumferance of the clutch. Read the volvospeed post once more and see if it makes more sense. If not, can you post a picture of your clutch or even post his picture and point to the "washers"?
Probably should have said to the left or right of the washer (or whatever it is).
On the attached photo (not mine), I can get the clips where the right arrow points. Can't get them where the left arrow points.
Will it matter?
-os
- ACClutchshim1.gif (73.79 KiB) Viewed 13698 times
2021 Honda Pilot
2021 Honda Pilot
- 14 Replies
- 6869 Views
Last post by oragex
- 1620 Views
Last post by 99TurboBrick
- 1699 Views
Last post by Griffe
- 15 Replies
- 4212 Views
Last post by erikv11
- 10 Replies
- 1716 Views
Last post by dikidera
