'98 S70 AC Recharge (high / low pressure lines)
moonboot
Year and Model:
Post by moonboot »
Hello,
I am going to attempt to recharge the AC today on my 1998 S70. I am aware of the warnings to use the valve on the low pressure line but does anybody know where this is (specifically)?
I do see the valve marked "nm" by the passanger headlight under the hood. Is this the correct valve?
Thank you.
Guest
Post by Guest »
That's the low-pressure valve. I've yet to see a high-pressure valve on mine. Just use the low-pressure, you can't charge on the high side anyway. Or I should say you shouldn't, it'll cause the can of refrigerent to explode. Not the desired effect....
WGRoper
Year and Model: 2009 XC90 3.2 FWD
Post by WGRoper »
Sorry, that was me, forgot to log in.
moonboot
Year and Model:
Post by moonboot »
Thanks,
I'll give that a shot and post the outcome, hopefully one which does not involve an exploding canister.
