Starting a Volvo 240 after sitting for 5 years, drain fuel Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
JasonZ
Post by JasonZ »
Hi, I'm trying to start/service a long sit 1990volvo 240DL sedan for a friend. The car belonged to her relative, so she has no available information on it.
The car was very well maintained before putting to storage ( garaged for 5 years ), no leak, 120k, everything looked extremely good for the age.
Here are the trouble I'm running in to:
If there was fuel, after five years, it should be in very bad condition. I wanted to change all the fuel out before attempting to start it. After hooking up a charged battery and turned the key to " on ", fuel gauge indicated no fuel, the needle was all the way down. Knocked on the fuel tank, sounded empty. I assumed that the tank was dry, the owner probably drained it before storing it. So I bought 2 gallons of fresh gasoline and added to the tank. Turned the key to on again, the needle was half way up. I don't think 2 gallons would be enough to raise the needle half way up. I never owned a volvo, so I don't really know how their fuel gauge work, is this normal? Can 2 gallons of gas do that? Or, was there fuel originally in the tank?
There was no drain plug for the gas tank. And it seems like this volvo has 2 fuel pumps. What is the easiest way to drain the tank? Is removing it the only option?
Thanks !
dpauto.com
Year and Model:
Post by dpauto.com »
JasonZ,
Inside the fuel tank is the fuel level sender unit. After sitting for so many years it might have gotten stuck. it's not normal for 2 gallons to make a guage goes from empty to 1/2.
One way to drain this no-drain-plug fuel tank, beside using a syphon unit, is to remove the feed hose from the main pump (under car) and then energize the intank pump.
Regards,
Dave
ASE - VOLVO Master Technician
JasonZ
Post by JasonZ »
THank you Dave,
So to energize the tank pump, I'm thinking taking off the fuses to main fuel pump and starter, disconnect the ignition wiring and then crank it, or should I direct power directly to it? 12 volt? or maybe less? But if I use this method, am I risking turning the fuel pump dry? In some Japanese old vehicles, running the fuel pump dry can do great damage since gasoline help cool and lubricate the pump.
I tried to put a tube down the tank and suck the fuel out, but the path way seems to be restricted, I couldn't reach the bottom. Is it really restricted? probably by the pump and level float?
sincerely
Jason
dpauto.com
Year and Model:
JasonZ,
Do this:
With KEY OFF...
>disconnect the feed hose to the main pump (use any source of container to catch the fuel)
>disconnect the yellow connector at the main pump ( to disable)
>at your fuse panel, find a live fuse and power it to the Intank Fuel Pump fuse ( this will immediately energize the intank pump .. assuming the intank pump is working)
>watch closely as the fuel being pumped out ... when a stream of fuel becomes weak to nothing, stop energizing the intank pump.
>reinstall the feed hose and reconnect the yellow connector back to main pump.
>DONE!
Regards,
Dave
JasonZ
Post by JasonZ »
Thank you, I understood everything on the list besides the fuse box part. What do you mean by live fuse? a 12V DC?
THank you so much!
JasonZ
Post by JasonZ »
And one more thing, if feeding a 12V DC, which lead is positive?
Also, do you have a spec sheet for maintance? or a link on the web? Such as, engine oil grade (10w-40/30? I think?) Suggested coolant type and concentration, brake fluid type, automatic transmission fluid type and capacity... etc
I'm sorry I asked alot of questions, it's very hard to find repair manual in local automotive stores.
Thank you!
Jason Z
dpauto.com
Year and Model:
JasonZ wrote:Thank you, I understood everything on the list besides the fuse box part. What do you mean by live fuse? a 12V DC?
With key off, a live fuse is a fuse that still have power even with key off. With a test light, you can easily find one. Once you locate the live fuse, take a jumper wire with aligator clips and connect that live fuse to energize the Intank Pump fuse.
JasonZ wrote:Also, do you have a spec sheet for maintance? or a link on the web? Such as, engine oil grade (10w-40/30? I think?) Suggested coolant type and concentration, brake fluid type, automatic transmission fluid type and capacity... etc
Engine Oil (10-30W is standard)
Coolant (any green type)
Brake fluid (Dot 3 or 4 )
Transmission Fluid (Dex-II or III, total capacity approx. 7 qts./ drain-refill 2.6 qts.)
Power Steering (ATF Type F)
