N/A tuning 20V, VVIS, something diffirent.
This topic is in the MVS Volvo Repair Database » Improve Air Delivery to N/A Engines w/ VVIS Mod
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
Razorx, thanks for the VVIS update. I would guess that the 1995 anomaly you discovered would exist in North America also, because North America would generally get Volvos/Volvo updates later than Europe in the early era of the 850 line.
As for the contributions you'd like to make, please do :-). Do any of the following if they help:
A. write in Dutch (or whatever your native language) and use Google's free translation service to transform it into English;
B. write in English because it's not bad;
C. send either A or B to me and I'll clean it up;
D. or simply post either A or B and I'll clean it up "on the fly".
Also -> Amazon link
razorx
Year and Model: 855 '96, 854 '93
Post by razorx »
My appologies Matthew, I missed your last post.
I have been quite busy with our new home server and some very bad spam filters.
Today, after two years of playing and testing, together wit other people I dared to take the big step:
I will try to sell these circuit boards on ebay. I am not soure if it is allowed to share the link on this site, so forgive me.
If not pls.kill the link ;)
http://cgi.ebay.nl/ws/eBayISAPI.dll?Vie ... 0736149810
I really hav no idea weather there will be any reaction on ebay or yust too much. Exiting.
But who doesnt dare never wins.
I have made an index of the blog of my car on this page:
http://www.volvo850forum.nl/index.php/t ... 665.0.html
With the Google translate function the results are sort of readable.
Most of it is quite standard and you will find similar information on this forum.
But as allways, sometimes there is a more easy way to do things and maybe it is good to share:
Working on your CV joints: You dont need to touch this hopeless 36 bolt. ;)
Starter engine replacement: I have to put a simplified update on this site.
Talking to the lpg ecu's: Most systems use the same hardware interface, only different connectors and software.
A lot of manufacturers are quite friendly and will share it.
On the forum I mentioned above, you can find a good lot of information of chipped Turbo engines running on LPG by the way.
Anyway kind regards,
Yits.
Dirk342
Year and Model: 850-1993
Post by Dirk342 »
It is as easy as Razorx descripes, it will fit and work on all the cars with a VVIS manifold, regardless how old the car maight be. Regardless how big the engine is, 2.0 Ltr or 2.5 ltr engines. The most significant difference I noticed was on a Italian 2.0-20V engine wich runs on LPG.
One small hint, please weld the connectors very well, otherwise there is a change on mailfunction. So don't use the blue or red Scotch Locks.
turbozutek
Year and Model: 1995 850 GLE
Post by turbozutek »
I recently did the YITSBox Mod:
YitsBox Mod and Harness.jpg (88.02 KiB) Viewed 7075 times
The quality of construction is top notch. Good components, a well designed PCB and the solder (all done by hand) was utterly perfect; I couldn't improve upon a thing on the hardware. I got this delivered at 9am and by 9:10 I was building a cable loom for it! Yits included all the connectors and the mounting hardware needed in the kit, all I had to get was two lengths of two core automotive cable and a metre of four core.
Making A Hole.jpg (75.4 KiB) Viewed 7075 times
While most installations of this unit were to a LHD car, mine is a RHD... The instructions are mostly the same of course, the only difference being you need slightly longer cables and it's inconvenient to route the cables via the fusebox, as your loom would have to pass the hot exhaust manifold. Instead, I lead the loom over the centre console and behind the glovebox - from there I found the original unused Volvo grommet, removed it and made a hole in the sound damping foam.
It pokes out just in front of the air recycling flap and from there it routes to behind the glovebox.
Cables Installed In Grommet.jpg (70.33 KiB) Viewed 7075 times
The original Volvo grommet just needs snipped in two places and with a little silicone grease becomes 100% water-tight again.
Cables Tidied Up.jpg (88.81 KiB) Viewed 7075 times
The routing under the bonnet (hood) - I basically followed the ABS loom here, first connection branching to the coil while the other runs behind the battery to the solenoid.
YitsBox Mod Installed.jpg (83.71 KiB) Viewed 7075 times
Doesn't look out of place in the slightest, a very clean almost 'factory' look! :)
Now, the important question; how well does it work? The answer is ... VERY WELL! The timidity of the 2.0 engine is totally gone and it pulls like a train from almost nothing. I have the 4 speed Auto and I have to say this car is now 10 times nicer to drive, the pick up is improved and any nervousness the car had is gone. The car changes down a lot less when dealing with roundabouts, which is a vast improvement and the feeling of being exactly in the wrong gear on corners has lessened considerably.
Overtaking is a joy, as when you hit around 4.1k, the system opens both channels inside the inlet and you can actually feel a tiny sensation in the seat of your pants as the car continues to develop power all the way to the red-line.
In short, it's very good!
Chris...
Dirk342
Post by Dirk342 »
I see that you put the VVIS mod into a 2.0 ltr engine. Amazing what kind of change that mod proves in driving the car. When you drive a 2.0 ltr engine, running on LPG (what happens a lot in the Netherlands) with the 4 automatic gearbox the improvement is far more bigger and better.
Nice to see that you also like the change !
Regards, Dirk
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Thanks for the RHD write-up!!
I just purchased a '95 VVIS inlet manifold engine and transmission from a pick and pull with 114K (that's kilometres so around 75K miles) and I'm looking for a suitable donor car. The bottom end is going into a '99V70 but I have another block which is being built into a 20 valve (originally a 10 valve)
I would love to try this out also. Can't wait now to try it!!
razorx
Post by razorx »
@Chris (turbotuzek): Thank you for your positive feedback.
I noticed you did the wiring very neat.
I will modify the manual because of the need for longer wires in a right hand driven car.
Again thank you for your enthusiasm.
Kind regards,
Yits.
I know this is a silly question, but how did Volvo arrange the timing of the fully open position of the valves from factory?
Sorry just read the first post and I can see how Volvo arranged it. This certainly is much better. Nobody wants full torque above 4100rpm!!
shiloh51933
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
I basically just read this whole thread and I'm curious to say the least. I have a 1996 850 GLT(Northern America) and I'm curious to find out if this would work on my 850 with the air box thermostat mod/ throttle body plate from the 960. I could easily undo the airbox thermostat but wouldn't think of not using the throttle body plate. Could I possible use this mod that Razorx invented with what I got? Thanks.
I just went outside w/flash light to check...no solenoid in spot shown in pic. I'm guessing this is a Euro thing, thanks anyway.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
turbozutek
shiloh51933 wrote: I just went outside w/flash light to check...no solenoid in spot shown in pic. I'm guessing this is a Euro thing, thanks anyway.
By 1996 Volvo had abandoned the system and VVIS was no longer fitted. They should have talked to Yits instead of removing it, lol! :mrgreen:
